Expand my Community achievements bar.
Attachments when render a form
Avatar
Former Community Member
I recently join adobe livecycle platform and i using it to develop an application that uses forms.<br /><br />I want to permit attachments in my forms but i find and issue that i can´t manage. Seems like newbie question but i read km of documentation and my dubt persists.<br /><br />I want to put a description for my attachments when render a form but seems that Map<String, Document> that i pass on renderForm method dont have any maner of indicate this.<br /><br />I really apreciate any help in this direcction. Some manual or something that i miss.<br /><br />Thank you in advance for any help.<br />Cheers.
Avatar
So do you want to put attachments in to the form , or you want to put attachments to the task.Let me know will give the proper solution
thanks
mergeandfuse@gmail.com
Avatar
When you generate the form with some attachments then you have an attachment button. When you hit that button a table with attachments appear.
The table have 4 columns:
- Name
- Description
- Date
- Size
I can set name correctly but Description is filled with something like $FS_TIMESTAMP=121111234322232. I want to set a description but i cant find where.
Im trying to do this using Forms Service with Java Api.
Thks for help.
Avatar
Hi,<br /><br />I have the same question. I've used the setDocAttribute method to set the "description" attribute for the attachment, but then I end up with<br />the description showing up as<br /><br /><my description> $FS_TIMESTAMP=1234....<br /><br />Is there anyway to prevent the $FS_TIMESTAMP from being appended?<br /><br />Thanks.
Avatar
Was anyone able to find a fix for this issue? We are experiencing the same.
Thanks!
Avatar
Hi Brian
Do you want to add attachments to the "FORM" or you want attachments added to the attachment tab of the workspace when the form is rendered?
let me know
thanks
girish
Avatar
I would like to do something similar attaching to the FORM.
