0 Replies Latest reply on Jul 7, 2008 9:36 AM by (Kyle_A_Black)
    Workbench won't copy/paste nodes
    Level 1
      Hello all,
      I have some sections of a process that are very similar, and would like to copy/paste them so that I don't have to set up each node individually again. The nodes I'm trying to copy/paste are on a branch inside a gateway element. Workbench is acting rather funny about this. Some nodes will copy/paste fine, but the majority will not. I've also tried to copy the entire branch but this has the same outcome as those nodes that won't copy/paste. Sometimes the nodes will copy/paste but workbench won't recognize that they are there (meaning they show up on the workflow, but when you try to click on them to set properties workbench never selects the node, and lists "Nothing Selected" in the properties window). The JBoss log does not show any errors, but if I dig into the Eclipse log, I see the following errors:
      !ENTRY org.eclipse.ui 4 4 2008-07-07 12:52:32.771
      !MESSAGE Unhandled event loop exception
      !ENTRY org.eclipse.ui 4 0 2008-07-07 12:52:32.771
      !MESSAGE java.lang.NullPointerException
      !STACK 0
      at com.adobe.workflow.eclipse.template.ProcessTemplateView.acceptOrRejectPaste(ProcessTempla teView.java:1175)
      at com.adobe.workflow.eclipse.template.ProcessTemplateView.paste(ProcessTemplateView.java:10 98)
      at com.adobe.workflow.eclipse.template.AbstractTemplateView.doMouseUp(AbstractTemplateView.j ava:1039)
      at com.nwoods.jgo.JGoView.mouseUp(Unknown Source)
      at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:137)
      I've tried restarting Workbench, and the LiveCycle server, but neither will allow the copy/paste to happen. Anyone else ever seen this, or know how to resolve it?
