I am triying to define a new event in BAM application workbench.
I am getting the following error even I use the predefined JDBC
agent "adobe_jdbc_agent" in BAM workbench.The error detail is below.
Could anyone tell me what is wrong and how can I fix it?
Cihan
Unable to get metadata for query [select commonname from edcprincipalentity] from database connection [ADOBE_JDBC_AGENT].
Caused by:
No operations allowed after connection closed.Connection was implicitly closed due to underlying exception/error:
** BEGIN NESTED EXCEPTION **
com.mysql.jdbc.CommunicationsException
MESSAGE: Communications link failure due to underlying exception:
java.net.SocketException
MESSAGE: Software caused connection abort: socket write error
STACKTRACE:
java.net.SocketException: Software caused connection abort: socket write error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:92)
at java.net.SocketOutputStream.write(SocketOutputStream.java:136)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:65)
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:123)
at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2692)
at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2621)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1552)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1666)
at com.mysql.jdbc.Connection.execSQL(Connection.java:2994)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:936)
at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1030)
at org.jboss.resource.adapter.jdbc.WrappedPreparedStatement.executeQuery(WrappedPreparedStatement.java:211)
at com.celequest.datasources.adapter.PreparedStatementManager.query(PreparedStatementManager.java:197)
at com.celequest.datasources.adapter.JDBCAdapter.query(JDBCAdapter.java:175)
at com.celequest.datasources.source.jdbcSource.bindAndExecuteUtil(jdbcSource.java:314)
at com.celequest.datasources.source.jdbcSource.bindAndExecuteCreateIter(jdbcSource.java:351)
at com.celequest.datasources.polling.JDBCPoller.executeQuery(JDBCPoller.java:109)
at com.celequest.datasources.polling.Poller.doExecuteQuery(Poller.java:638)
at com.celequest.datasources.polling.Poller.executeQuery(Poller.java:599)
at com.celequest.datasources.polling.IntervalPoller.run(IntervalPoller.java:191)
at com.celequest.datasources.polling.IntervalPoller$MyTimerTask.run(IntervalPoller.java:55)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
** END NESTED EXCEPTION **
Last packet sent to the server was 0 ms ago.
STACKTRACE:
com.mysql.jdbc.CommunicationsException: Communications link failure due to underlying exception:
STACKTRACE:
