4 Replies Latest reply on Jul 28, 2008 10:31 PM by (jerome_dinnat)
    Compare String
    (jerome_dinnat) Level 1
      I want to compare strings in a route condition.
      I have two strings /process_data/@string1 and /process_data/@string2
      I fill the box of the properties route conditions like that :
      /process_data/@string1 = /process_data/@string2
      I try many other ways but it doesn't work so I think I'm wrong
      I use a variable logger in the process with the strings length and the strings :
      string1 :
      /process_data/@tailleCourrant - java.lang.Integer: 10
      /process_data/@nplusunEnCours - String: AALBERTEAU
      string2 :
      /process_data/@tailleEntree - java.lang.Integer: 10
      /process_data/@nplusUnEntree - String: AALBERTEAU
      The only difference I see is the blank before the strings but I can't erase them and the length are the same so I think there is no matter of that.
      Edit : I try this in condition :
      "test" = "test" and It works fine so I suppose my two string are different but I know there are the same and the logger say that. I don't understand the spaces before the string. I try normalize-space but It doesn't work to.
