Expand my Community achievements bar.
WorkBench 8.2 on ES 8.0
Avatar
Former Community Member
If I upgrade my WorkBench to 8.2 (Update-1),
will I still be able to use it to fully access an 8.0 ES server?
thanks
James
Avatar
I believe it will work fine, but some functionality will not be available, of course because of LC not being version 8.2.
Avatar
well, following your belief, I installed 8.2 WorkBench,
but when I tried to connect to an 8.0 server,
it popped up an error message:
this version of WorkBench is incompatible with server !!!!!!!!
ARGH!!!!
so you can't have 8.0 and 8.2 servers in the same company?!
there's no backward compatibility?!?!
that's very inconvenient....
Avatar
That was a bit unexpected. However, we are running both ES 8.0 and 8.2, and I have both versions of workbench installed on my computer, so you can have both versions. I should have told this earlier. Anyway, I hope you will be able to install workbench 8.0 again, in addition to workbench 8.2.
Avatar
Hi, I got a new problem...
this is what has happened:
1. I deinstalled 8.0 WorkBench
2. installed 8.2 WorkBench
3. discovered 8.2 WorkBench couldn't access 8.0 server (see above)
4. so I deinstalled 8.2 WorkBench
5. reinstalled 8.0 WorkBench
6. but it now gives me an error message saying,
either my Configuration (server name, port) is wrong
or my ID/password is wrong,
or the server is not running.
I checked everything, couldn't see anything wrong.
I can login to WorkSpace and AdminUI,
server is running fine, no error in server log whatsoever.
How do I revive my WorkBench? please advise.
thanks
Avatar
Sorry, I don't have any answer to this at the moment. I will let you know if I find something. You could ask Adobe support.
