2 Replies Latest reply on Aug 6, 2008 6:27 AM by (thomas_belarbi)
    can't reassign task !
      Hi everybody!
      is here my code :
      //Set connection properties
      Properties ConnectionProps = new Properties();
      ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT, "jnp://");
      ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL,Service ClientFactoryProperties.DSC_EJB_PROTOCOL);
      ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE, ServiceClientFactoryProperties.DSC_JBOSS_SERVER_TYPE);
      ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, "apink");
      ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, "password");
      //Create a ServiceClientFactory object
      ServiceClientFactory myFactory = ServiceClientFactory.createInstance(ConnectionProps);
      //Create a TaskManager object
      TaskManager myTaskManager = TaskManagerClientFactory.getTaskManager(myFactory);
      //Get the user identifer by calling
      //a user-defined method
      String userID = getUserId(myFactory);
      //Forward task to another user
      catch(Exception e)
      As you can see, I use the user apink ( because it's the owner of the task N°17 )
      my method getUserId() :
      static private String getUserId(ServiceClientFactory myFactory){
      String oid = "";
      //Create a DirectoryManagerServiceClient object
      DirectoryManagerServiceClient dirClient = new DirectoryManagerServiceClient(myFactory);
      //Find a local user
      PrincipalSearchFilter psf = new PrincipalSearchFilter();
      List principalList = dirClient.findPrincipals(psf);
      Iterator pit = principalList.iterator();
      User testUser = null;
      if (pit.hasNext())
      //Obtain the principals object identifier
      testUser = (User)(pit.next());
      oid = testUser.getOid();
      catch(Exception e)
      return oid;
      I have this exception :
      com.adobe.pof.POFException: No Active User in an Active Domain found for Principal ID:
      If I use "administrator" instead of "apink" I have this exception
      com.adobe.idp.taskmanager.dsc.client.task.TaskNotFoundException: Task: 17 was not found, or it is not in the correct state for the operation you are attempting - task not reassigned.
      Anyone have an Idea ?
