10 Replies Latest reply on Jun 28, 2009 12:00 AM by $Nith$
    Form will not render from Workspace
    JoshDBoyle Level 1
      I have an xfaForm that will be filled out to kick off a workflow via a TaskManager endpoint. However, when I try to start the workflow from within Workspace, it throws the following error code at me:
      I have triple checked that my form and workflow meet the following criteria:
      1) The variable I am using for my form is of type xfaForm
      2) The variable I am using for my form is set to both "Input" and "Required"
      3) The render service for the form is set to "Default Render" (invoke)
      4) A button exists on the form and is set to "Submit"
      I was under the impression that should the above for criteria be met, that a form should render but am I missing something?
      Thanks in advance!
