15 Replies Latest reply on Aug 20, 2008 7:04 AM by (Siham_Aboumadi)
    Problem "send Email with Attachment"
      I want send an Email with Attachment but I can't attach "xfa","Document Form" type to my mail.
      I have :
      Cannot coerce object: com.adobe.idp.taskmanager.form.impl.binarycontent.BinaryContentFormInstance@49dda9 of type: com.adobe.idp.taskmanager.form.impl.binarycontent.BinaryContentFormInstance to type: interface java.util.List: ALC-DSC-119-000: com.adobe.idp.dsc.util.InvalidCoercionException: Cannot coerce object: com.adobe.idp.taskmanager.form.impl.binarycontent.BinaryContentFormInstance@49dda9 of type: com.adobe.idp.taskmanager.form.impl.binarycontent.BinaryContentFormInstance to type: interface java.util.List
      at com.adobe.idp.dsc.util.CoercionUtil.toMap(CoercionUtil.java:1201)
      at com.adobe.idp.dsc.util.CoercionUtil.toType(CoercionUtil.java:981)
      and more.
      Any ideas?
      Thanks.
        • 1. Re: Problem "send Email with Attachment"
          Jasmin Charbonneau Level 4
          The Email with Attachment expects the content of attachment to be in a 'document' variable.
          If you want to attach the a Document Form, you would have to extract the content of that variable and put it in a 'document' variable.
          Jasmin
          • 2. Re: Problem "send Email with Attachment"
            Level 1
            Thanks.
            But how can it be done ?
            Can I get attributes of Document Form ?
            • 3. Re: Problem "send Email with Attachment"
              Sure you can.
              You can use a xPath expression in a setValue. Something like /process_data/MyDocumentForm/object/document.
              This will give you data for the Document Form variable.
              Jasmin
              • 4. Re: Problem "send Email with Attachment"
                Workbench ES Help documents the attributes for all variable types.
                For Document Form, click Data Items in this topic:
                http://livedocs.adobe.com/livecycle/es/wb_help/00000752.html
                scott
                • 5. Re: Problem "send Email with Attachment"
                  Level 1
                  When I put /process_data/NameForm/object/@document in a String I have :
                  rO0ABXNyABZjb20uYWRvYmUuaWRwLkRvY3VtZW50yAEFUxsO+CEDACNJAAtfY2FsbGJhY2tJZFoADV9kZXNlcmlhbG l6ZWRJABBfZGlzcG9zYWxUaW1lb3V0WgAJX2Rpc3Bvc2VkWgAZX2lzRGlzcG9zYWxUaW1lb3V0RGVmYXVsdFoAE19p c1RyYW5zYWN0aW9uQm91bmRKAAdfbGVuZ3RoSQAOX21heElubGluZVNpemVaAAhfb3duRmlsZVoAC19wYXNzaXZhdG VkWgALX3BlcnNpc3RlbnRJABFfc2VuZGVyQ2FsbGJhY2tJZFoAEV9zZW5kZXJQYXNzaXZhdGVkWgARX3NlbmRlclBl cnNpc3RlbnRJAA5fc2VuZGVyVmVyc2lvbkkABl9zdGF0ZUwAC19hdHRyaWJ1dGVzdAATTGphdmEvdXRpbC9IYXNoTW FwO0wACF9jYWNoZUlkdAAfTGNvbS9hZG9iZS9pZHAvRG9jdW1lbnRDYWNoZUlEO0wADF9jYWxsYmFja1JlZnQAIUxj b20vYWRvYmUvaWRwL0lEb2N1bWVudENhbGxiYWNrO0wADF9jb250ZW50VHlwZXQAEkxqYXZhL2xhbmcvU3RyaW5nO0 wAC19kYXRhQnVmZmVydAAeTGNvbS9hZG9iZS9zZXJ2aWNlL0RhdGFCdWZmZXI7TAAPX2V4cGlyYXRpb25UaW1ldAAQ TGphdmEvbGFuZy9Mb25nO0wABV9maWxldAAOTGphdmEvaW8vRmlsZTtMABBfZ2xvYmFsQmFja2VuZElkdAAhTGNvbS 9hZG9iZS9pZHAvRG9jdW1lbnRCYWNrZW5kSUQ7WwAHX2lubGluZXQAAltCTAAMX2lucHV0U3RyZWFtdAAVTGphdmEv aW8vSW5wdXRTdHJlYW07TAAPX2xvY2FsQmFja2VuZElkcQB+AAhMAAxfcHVsbFNlcnZhbnR0ACRMY29tL2Fkb2JlL2 lkcC9JRG9jdW1lbnRQdWxsU2VydmFudDtMABFfcmFuZG9tQWNjZXNzRmlsZXQAGkxqYXZhL2lvL1JhbmRvbUFjY2Vz c0ZpbGU7TAAVX3NlbmRlckNhbGxiYWNrUmVmSU9ScQB+AARMABZfc2VuZGVyR2xvYmFsQmFja2VuZElkcQB+AAhMAA 1fc2VuZGVySG9zdElkcQB+AARMABVfc2VuZGVyTG9jYWxCYWNrZW5kSWRxAH4ACEwAGl9zZW5kZXJQdWxsU2VydmFu dEpuZGlOYW1lcQB+AARMAARfdXJsdAAOTGphdmEvbmV0L1VSTDt4cHcGAAAAAwAAcHcaABgxMjcuMC4wLjEvMTcyLj MxLjE5Ni4xNzFwcHNyABxjb20uYWRvYmUuaWRwLkRvY3VtZW50RmlsZUlEr8db9jDMnqUCAAFMAAlfZmlsZU5hbWVx AH4ABHhwdABNc2Vzc2lvbl93ZnRhc2tmb3JtaWQ3MTYvLi4vZG9jbTEyMTg2MjEyOTMwMDgvY2YwNjhmNzAyMmI0Mj A4ODAzNzllOGRiZjNiNDk1YTR0AA9hcHBsaWNhdGlvbi9wZGZwc3IAEWphdmEudXRpbC5IYXNoTWFwBQfawcMWYNED AAJGAApsb2FkRmFjdG9ySQAJdGhyZXNob2xkeHA/QAAAAAAADHcIAAAAEAAAAAN0AAx0ZW1wbGF0ZVBhdGh0ACcvUE 9Dcy9GVCBTSSBSSC9Gb3JtdWxhaXJlQWJzZW5jZSBWMi5wZGZ0AAl1c2VyQWdlbnR0AFlNb3ppbGxhLzUuMCAoV2lu ZG93czsgVTsgV2luZG93cyBOVCA1LjE7IGZyOyBydjoxLjguMS4xNikgR2Vja28vMjAwODA3MDIgRmlyZWZveC8yLj AuMC4xNnQAC2Vudmlyb25tZW50dAEHJkhUVFBfQUNDRVBUX0xBTkdVQUdFPWZyLGZyLWZyO3E9MC44LGVuLXVzO3E9 MC41LGVuO3E9MC4zJkhUVFBfSE9TVD1pdGVtLTU1NjY3OjgwODAmSFRUUF9VU0VSX0FHRU5UPU1vemlsbGEvNS4wIC hXaW5kb3dzOyBVOyBXaW5kb3dzIE5UIDUuMTsgZnI7IHJ2OjEuOC4xLjE2KSBHZWNrby8yMDA4MDcwMiBGaXJlZm94 LzIuMC4wLjE2JkNPTlRFTlRfVFlQRT1hcHBsaWNhdGlvbi9wZGYmQ09OVEVOVF9MRU5HVEg9NDcwOTQ1JlNFUlZFUl 9OQU1FPWl0ZW0tNTU2Njd4dzcALWFkb2JlL2lkcC9Eb2N1bWVudFB1bGxTZXJ2YW50L2Fkb2JlamJfc2VydmVyMQAA AAAABy+heA==
                  I tried to put this in a xfa but it didn't work.
                  thanks.
                  • 6. Re: Problem "send Email with Attachment"
                    Level 1
                    in the email component for the attachment variable,drill down into the documentForm object and select the document node.This will send the document as email attachment
                    girish
                    mergeandfuse@gmail.com
                    • 7. Re: Problem "send Email with Attachment"
                      Level 1
                      I tried to put in Attachments field :
                      I have an exception to "Send Email with Attachments":
                      Cannot coerce object ...
                      And I tried to put /process_data/NameForm/object/@document in a document variable but I have the same exception type.
                      • 8. Re: Problem "send Email with Attachment"
                        Try to put it in an document variable instead of accessing the property of the Document Form. The way you do it should be fine, but for some reason LC might not like it.
                        Just use a setValue before and extract the document in a document variable and see if that works.
                        Jasmin
                        • 9. Re: Problem "send Email with Attachment"
                          Level 1
                          I tried to put /process_data/NameForm in a document variable (with a setValue) and send it, but exception.
                          I tried to put /process_data/NameForm/object/@document in a document variable, with a setValue, and, after, export this document variable(with exportData) in an other document variable and send it, but exception.
                          • 10. Re: Problem "send Email with Attachment"
                            What's the exception?
                            Jasmin
                            • 11. Re: Problem "send Email with Attachment"
                              Level 1
                              Cannot coerce object: <document state="passive" senderVersion="3" persistent="false" senderPersistent="true" passivated="true" senderPassivated="true" deserialized="true" senderHostId="127.0.0.1/172.31.196.171" callbackId="0" senderCallbackId="0" callbackRef="null" isLocalizable="true" isTransactionBound="false" defaultDisposalTimeout="600" disposalTimeout="600" maxInlineSize="65536" defaultMaxInlineSize="65536" inlineSize="0" contentType="application/pdf" length="478293"><cacheId/><localBackendId/><globalBackendId><DocumentFileID fileName="D:\Adobe\LiveCycle8.2\jboss\server\all\svcnative\DocumentStorage\docm1219048296 646\bb4e96fcaf58da04a338b1022370c9ad"/><globalBackendId/><senderLocalBackendId/><senderGlo balBackendId><DocumentFileID fileName="D:\Adobe\LiveCycle8.2\jboss\server\all\svcnative\DocumentStorage\docm1219048296 646\bb4e96fcaf58da04a338b1022370c9ad"/><senderGlobalBackendId/><inline/><senderPullServant JndiName>adobe/idp/DocumentPullServant/adobejb_server1</senderPullServantJndiName><attribu tes ADOBE_SHAREDPDFDOCUMENT_NEEDS_COPY="true" templatePath="/POCs/FT SI RH/FormulaireAbsence V2.pdf" userAgent="Mozilla/5.0 (Windows; U; Windows NT 5.1; fr; rv:1.8.1.16) Gecko/20080702 Firefox/2.0.0.16" environment="&HTTP_ACCEPT_LANGUAGE=fr,fr-fr;q=0.8,en-us;q=0.5,en;q=0.3&HTTP_HOST=item-556 67:8080&HTTP_USER_AGENT=Mozilla/5.0 (Windows; U; Windows NT 5.1; fr; rv:1.8.1.16) Gecko/20080702 Firefox/2.0.0.16&CONTENT_TYPE=application/pdf&CONTENT_LENGTH=478293&SERVER_NAME=item-5566 7" ADOBE_SAVE_MODE_ATTRIBUTE="NO_CHANGE" ADOBE_SAVE_MODE_FORCE_COMPRESSED_OBJECTS_ATTRIBUTE="false" ADOBE_SAVE_MODE_REQUIRED_ATTRIBUTE="false"/></document> of type: com.adobe.idp.Document to type: interface java.util.List: ALC-DSC-119-000: com.adobe.idp.dsc.util.InvalidCoercionException: Cannot coerce object: <document state="passive" senderVersion="3" persistent="false" senderPersistent="true" passivated="true" senderPassivated="true" deserialized="true" senderHostId="127.0.0.1/172.31.196.171" callbackId="0" senderCallbackId="0" callbackRef="null" isLocalizable="true" isTransactionBound="false" defaultDisposalTimeout="600" disposalTimeout="600" maxInlineSize="65536" defaultMaxInlineSize="65536" inlineSize="0" contentType="application/pdf" length="478293"><cacheId/><localBackendId/><globalBackendId><DocumentFileID fileName="D:\Adobe\LiveCycle8.2\jboss\server\all\svcnative\DocumentStorage\docm1219048296 646\bb4e96fcaf58da04a338b1022370c9ad"/><globalBackendId/><senderLocalBackendId/><senderGlo balBackendId><DocumentFileID fileName="D:\Adobe\LiveCycle8.2\jboss\server\all\svcnative\DocumentStorage\docm1219048296 646\bb4e96fcaf58da04a338b1022370c9ad"/><senderGlobalBackendId/><inline/><senderPullServant JndiName>adobe/idp/DocumentPullServant/adobejb_server1</senderPullServantJndiName><attribu tes ADOBE_SHAREDPDFDOCUMENT_NEEDS_COPY="true" templatePath="/POCs/FT SI RH/FormulaireAbsence V2.pdf" userAgent="Mozilla/5.0 (Windows; U; Windows NT 5.1; fr; rv:1.8.1.16) Gecko/20080702 Firefox/2.0.0.16" environment="&HTTP_ACCEPT_LANGUAGE=fr,fr-fr;q=0.8,en-us;q=0.5,en;q=0.3&HTTP_HOST=item-556 67:8080&HTTP_USER_AGENT=Mozilla/5.0 (Windows; U; Windows NT 5.1; fr; rv:1.8.1.16) Gecko/20080702 Firefox/2.0.0.16&CONTENT_TYPE=application/pdf&CONTENT_LENGTH=478293&SERVER_NAME=item-5566 7" ADOBE_SAVE_MODE_ATTRIBUTE="NO_CHANGE" ADOBE_SAVE_MODE_FORCE_COMPRESSED_OBJECTS_ATTRIBUTE="false" ADOBE_SAVE_MODE_REQUIRED_ATTRIBUTE="false"/></document> of type: com.adobe.idp.Document to type: interface java.util.List<br />     at com.adobe.idp.dsc.util.CoercionUtil.toMap(CoercionUtil.java:1201)<br />     at com.adobe.idp.dsc.util.CoercionUtil.toType(CoercionUtil.java:981)<br />     at com.adobe.workflow.datatype.CoercionUtil.toType(CoercionUtil.java:168)<br />     at com.adobe.workflow.engine.PEUtil.processMapping(PEUtil.java:952)<br />     at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:658)<br />     at com.adobe.workflow.engine.SynchronousBranch.handleInvokeAction(SynchronousBranch.java:465 )<br />     at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:862)<br />     at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBea n.java:2773)<br />     at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncContinueBranchCommand(ProcessEngineBM TBean.java:2528)<br />     at sun.reflect.GeneratedMethodAccessor1208.invoke(Unknown Source)<br />     at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)<br />     at java.lang.reflect.Method.invoke(Method.java:585)<br />     at org.jboss.invocation.Invocation.performCall(Invocation.java:345)<br />     at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:214)<br />     at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:149)<br />     at org.jboss.webservice.server.ServiceEndpointInterceptor.invoke(ServiceEndpointInterceptor. java:54)<br />     at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:48) <br />     at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:106)<br />     at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 58)<br />     at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:62)<br />     at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:154)<br />     at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:153)<br />     at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:192)<br />     at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:122)<br />     at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:624)<br />     at org.jboss.ejb.Container.invoke(Container.java:873)<br />     at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:415)< br />     at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:88)<b r />     at $Proxy320.asyncContinueBranchCommand(Unknown Source)<br />     at com.adobe.workflow.engine.ProcessCommandControllerBean.doOnMessage(ProcessCommandControll erBean.java:144)<br />     at com.adobe.workflow.engine.ProcessCommandControllerBean.onMessage(ProcessCommandController Bean.java:99)<br />     at sun.reflect.GeneratedMethodAccessor962.invoke(Unknown Source)<br />     at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)<br />     at java.lang.reflect.Method.invoke(Method.java:585)<br />     at org.jboss.invocation.Invocation.performCall(Invocation.java:345)<br />     at org.jboss.ejb.MessageDrivenContainer$ContainerInterceptor.invoke(MessageDrivenContainer.j ava:475)<br />     at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:149)<br />     at org.jboss.ejb.plugins.MessageDrivenInstanceInterceptor.invoke(MessageDrivenInstanceInterc eptor.java:101)<br />     at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:106)<br />     at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:335)<br />     at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:166)<br />     at org.jboss.ejb.plugins.RunAsSecurityInterceptor.invoke(RunAsSecurityInterceptor.java:94)<b r />     at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:192)<br />     at org.jboss.ejb.MessageDrivenContainer.internalInvoke(MessageDrivenContainer.java:389)<br />     at org.jboss.ejb.Container.invoke(Container.java:873)<br />     at org.jboss.ejb.plugins.jms.JMSContainerInvoker.invoke(JMSContainerInvoker.java:1077)<br />     at org.jboss.ejb.plugins.jms.JMSContainerInvoker$MessageListenerImpl.onMessage(JMSContainerI nvoker.java:1379)<br />     at org.jboss.jms.asf.StdServerSession.onMessage(StdServerSession.java:256)<br />     at org.jboss.mq.SpyMessageConsumer.sessionConsumerProcessMessage(SpyMessageConsumer.java:904 )<br />     at org.jboss.mq.SpyMessageConsumer.addMessage(SpyMessageConsumer.java:160)<br />     at org.jboss.mq.SpySession.run(SpySession.java:333)<br />     at org.jboss.jms.asf.StdServerSession.run(StdServerSession.java:180)<br />     at EDU.oswego.cs.dl.util.concurrent.Pool
                              • 12. Re: Problem "send Email with Attachment"
                                Siham,
                                It looks like you are calling sendWithMapOfAttachments and passing a single document as the attachment? If you are only passing a single document, you should call SendWithDocument instead.
                                • 13. Re: Problem "send Email with Attachment"
                                  Level 1
                                  send me the process, will take a look
                                  • 14. Re: Problem "send Email with Attachment"
                                    The error essentially says that it cannot convert a content of type "document" into a list.
                                    Does that make sense with something you're doing?
                                    Jasmin
                                    • 15. Re: Problem "send Email with Attachment"
                                      Level 1
                                      Thanks everybody !!
                                      So, I used an activity from LC 8.0 on my Workbench 8.2.
                                      Now, I use "SendWithDocument" and it works!!!
                                      Thanks a lot.
