3 Replies Latest reply on Sep 10, 2010 8:18 AM by major6000
    LiveCycle workbench workspace is in use. You must close other
      Hi All,
      So we are trying to figure out how we would deploy the different tools
      to end users and developers. We chose to go the Citrix route. Upon
      installing workbench on the citrix box and testing to access, we got
      the following msg:
      "LiveCycle workbench workspace is in use. You must close other
      instance before proceeding."
      The way the problem was solved was to make the user an administrator
      on the server. That's really not going to fly at this client. Does
      anyone know why this was the case and how it could be fixed without
      making the user an administrator?
      What particular aspect did the user need to have rights so that the
      error msg wouldn't show up again?
      Please let me know and I definitely appreciate your help.
      Ikhide
        • 1. Re: LiveCycle workbench workspace is in use. You must close other
          I don't know if you need admin access, but Workbench certainly can't run in a locked down environment. By default it caches a lot of run time information in the install directory. For instance, I have Workbench installed in
          C:\Program Files\Adobe\LiveCycle80\Workbench ES.
          Under there is another directory called Workbench and under that is a directory called workspace i.e.
          C:\Program Files\Adobe\LiveCycle80\Workbench ES\Workbench\workspace
          That directory contains a .metadata directory which itself contains the Eclipse log (useful for whenever Workbench reports one of it's useless "see error log" error messages) plus some other stuff. When you are logged in, you'll see a directory named for the Workbench connection which, I think, contains cached information from the server.
          It's obvious that the workspace directory is in entirely the wrong place - I don't know what the Adobe engineers were thinking when they chose that location. There may be a config option to put it somewhere else, but I haven't found it yet.
          I was going to suggest giving users full access to just that workspace directory rather than making them full admins, but it occurs to me that, even then, only one person on the Citrix server will be able to use it at a time.
          • 2. Re: LiveCycle workbench workspace is in use. You must close other
            kc@dafolo.dk Level 1
            Hi all,
            If you set the working dir of the Workbench (on the Citrix server) to the users private dir (home dir or whatever you call it) you will fix this problem.
            Sincerely
            Kim
            • 3. Re: LiveCycle workbench workspace is in use. You must close other
              major6000
              Thanks for the response Kim. We decided that we weren't going to be deploying Workbench anymore
              so I stopped looking into this issue. Of course you know that changed right? TWO YEARS LATER!!! Lol. I was wondering if you could instruct me on how to
              setup the working directory locally for the user.
              Regards,
              Ikhide Akhigbe
