Expand my Community achievements bar.
xfaForm to Document Form
Avatar
Former Community Member
All
I have posted this before but with no responses. I need a means by which to go from an xfaForm to a Document Form. I realize the underlying differences between the two variable types but I believe there to be a way by which this can be done.
My reason for needing this ability is so that I can make use of an XFA ease of use throughout the workflow but then present a Document Form for Digital Signature capture and archival to an ECM.
1 Reply
Avatar
Level 4
Hi jboyle,
You can do the following:
1-Get data from your xfaForm using XPATH expressions and keep the xml data in a document variable
2-Use Forms' renderPDFFrom operation to merge your form template with data and assign the result to a document variable
3-set your rendered PDF document to /documentform/object/@document using setValue service
I hope this works.
Oguz
www.kgc.com.tr
