3 Replies Latest reply on Mar 10, 2009 4:45 AM by Jasmin Charbonneau
    Move Data Between 2 xfaForms
    The Flex Viking
      Assume I have process with 2 xfaForm variables, Form A (a PDF) and Form B (a PDF). A user fills out Form A. I want to populate values in Form B with the data from Form A.
      When I try to assign a value (using SetValue) directly from form A to form B, it doesn't seem to work. That is ...
      Location: /process_data/form_B/object/data/xdp/datasets/data/FormB/Value1
      Expression: /process_data/form_A/object/data/xdp/datasets/data/FormA/Value1
      It does work however when I use a temporary XML variable, say xml_data. That is, I move the data from Form A to xml_data, and the move the data from xml_data to Form B.
      Why would this be? What is wrong with directly moving data between my xfaForms? What am I missing?
