11 Replies Latest reply on Jan 25, 2011 7:48 AM by Jasmin Charbonneau
    Merging to xml variables with identical structure
    kc@dafolo.dk Level 1
      Hi all,
      I have two xml variables with identical structure, and I need to merge these two. How can I do this?
      Thanks in advance
      Sincerely
      Kim
        • 1. Re: Merging to xml variables with identical structure
          Jasmin Charbonneau Level 4
          What do you mean by merging the two xml?
          Copy the different elements of each node into the same node structure in the other xml?
          You would have to use the Script service or a custom component to do that?
          Jasmin
          • 2. Re: Merging to xml variables with identical structure
            Hi againn,
            An example might help here:
            I hvae two forms which share the same "master schema" that contains the superset of the elements of the two forms.
            So I have this:
            form1
            Name
            Address
            \form1
            form2
            Amount
            Creditcard
            \form2
            So for example I have an xml variable where one person has filled out all fields for form1 and now I want to put in these into another xml variable where another person (in parallel) has filled out all info in form2. How can this be done without making a assignment to each element one at a time.
            E.g. I don't wnat to do the following:
            myXml1/form1/Name = myXml2/form1/Name
            myXml1/form1/Address = myXml2/form1/Address
            Can I do this in just one step?
            Sincerely
            Kim
            • 3. Re: Merging to xml variables with identical structure
              You would have to group you elements.
              For example you could have
              form1
              Section1
              Name
              Address
              /Section1
              /form1
              form1
              Section2
              Amount
              CreditCard
              /Section2
              /form1
              That way you can do myXML1/form1/Section1 = myXML2/form1/Section1
              Otherwise you need to do it one by one or use a custom component.
              Jasmin
              • 4. Re: Merging to xml variables with identical structure
                parth pandya Level 2
                Hi Kim,
                Do you know xslt or xquery?
                I think doing the xml transformation via xslt or xquery would be an easier alternate for you compared to custom component or script.
                Parth
                • 5. Re: Merging to xml variables with identical structure
                  Hi again,
                  Thanks for the input - I got it to work by using your suggestion Jasmin.
                  To Parth: I am not aware how I can use XQuery with LC, can you send a link to where I could find more on this. Also I would like to know more on the XSLT transformations on xml files (I have not yet used them actively in my solutions).
                  If anyone has info (links or anything) on these issues I would like to hear about it :)
                  Thanks in advance
                  Sincerely
                  Kim
                  • 6. Re: Merging to xml variables with identical structure
                    Hi Kim,
                    To use XQuery with LC, you should install XQuery component as regular dsc and put it's operation as a step in your orchestration.
                    Example of it can be found at http://manly.avoka.com.au/confluence/display/Public/Transforming+XML+Documents
                    Have a look at www.w3schools.com for the xslt and xquery tutorials. XSLT and XQuery are really handy to know when you have to work with xml frequently.
                    Cheers,
                    Parth
                    • 7. Re: Merging to xml variables with identical structure
                      Aditya S. Level 1
                      I have a similar issue. The only difference is I have repeating subforms.<br /><br />XML1 contains non repeating subforms. XML2 contains repeating subforms.<br /><br />I would like to add XML2<br /><br /><form1><br />  <CompetencyDetails> <br />       <employee_firstname>Joe</employee_firstname> <br />       <employee_lastname/> <br />    </CompetencyDetails> <br />    <CompetencyDetails> <br />       <employee_firstname>Bob</employee_firstname> <br />       <employee_lastname/> <br />    </CompetencyDetails><br />    </Details><br /></form1> <br /><br />to XML1<br /><br /><form1><br />      </CompetencyDetails><br />      <Details> <br />       <review_from>01122009</review_from> <br />       <review_to>12122009</review_to> <br />       <evaluator_firstname>Sam</evaluator_firstname> <br />       <evaluator_lastname>Evaluator</evaluator_lastname> <br />    </Details><br /><form1><br /><br />Using SetValue I could not get <br /><br /><b>/process_data/xml/form1/CompetencyDetails=/process_data/xml2/form1/CompetencyDetails [*]</b><br /><br />to work. Any help will be highly appreciated.
                      • 8. Re: Merging to xml variables with identical structure
                        If you want to merge and have the following result
                               Joe
                               Bob
                               01122009
                               12122009
                               Sam
                               Evaluator
                        Then you could probably do something like
                        /process_data/xml2/form1/Details=/process_data/xml1/form1/Details/*
                        You want to avoid copying the content from the xml that has repeating nodes. In my example I keep the xml with the two repeating nodes (CompetencyDetails) intact and just copy the content of Details over.
                        Jasmin
                        • 9. Re: Merging to xml variables with identical structure
                          Aditya S. Level 1
                          Ha!! I never thought of that. Thank you Jasmin !!
                          You saved me a lot of code as I was planning to implement in a custom script.
                          Aditya
                          • 10. Re: Merging to xml variables with identical structure
                            Aditya S. Level 1
                            Jasmin - How is it possible to merge xml structures with repeating elements?
                            Aditya
                            • 11. Re: Merging to xml variables with identical structure
                              If you want to use the SetValue service, then you need to make sure to have a parent node for all the repeating nodes and copy that parent node over.
                              Remember, you can't really copy multiple nodes at the same level.
                              The other thing you can do it to use the Script service and use DOM manipulation to create your structure.
                              Jasmin
