5 Replies Latest reply on Feb 21, 2009 12:55 AM by HowardTreisman
    Inserting Multiple instances into a databse
    Aditya S. Level 1
      I am using MySQL to capture the form data. In the form I have a Driver License section which can have multiple instances.
      In the workflow I am using the "Execute SQL query" module to insert data. Initially I can insert information from the non-repeating subforms, successfully. However, workflow inserts no information from repeating subforms. Below is an example of the XPATH used.
      /process_data/xfaform/object/data/xdp/datasets/data/App/DriverLicense/drvlicstate
      Is the above format correct ? How can I insert the second and third instances ?
      Aditya
        • 1. Re: Inserting Multiple instances into a databse
          Jasmin Charbonneau Level 4
          You would need to call the "Execute SQL query" a second time and pass the information for the second driver licence section.
          Something like /process_data/xfaform/object/data/xdp/datasets/data/App/DriverLicense/drvlicstate[2]
          Jasmin
          • 2. Re: Inserting Multiple instances into a databse
            Aditya S. Level 1
            In my workflow, there could be different results of driver license information. Sometimes there could be one or more instances.
            Are you suggesting that I will need one SQL query for every instance ? Is there a way to created a loop ?
            "Something like /process_data/xfaform/object/data/xdp/datasets/data/App/DriverLicense/drvlicstate[2]"
            Just to clarify - would it be the DiverLicense[2] or drvlicstate[2] ? In other words, would I specify the instance on the subform or the field ?
            Aditya
            • 3. Re: Inserting Multiple instances into a databse
              Ryan Lunka Level 3
              Yes you can and will have to set up a loop in your process. Use an integer process variable as your loop increment start it at 1 (I'm pretty sure the indexing begins at 1...could be 0). You'll have to use the count() XPath function to count the number of nodes. Something like...
              count(/process_data/xfaform/object/data/xdp/datasets/data/App/DriverLicense/drvlicstate)
              Compare that number with the index value to know if you've looped through every node (and inserted each, one at a time) or if you need to loop again. Email me and I'd be glad to discuss this further with you if need be. It's not as complicated as it sounds.
              Hope this helps!
              Ryan D. Lunka
              Cardinal Solutions Group
              rlunka@cardinalsolutions.com
              • 4. Re: Inserting Multiple instances into a databse
                "Just to clarify - would it be the DiverLicense[2] or drvlicstate[2] ? In other words, would I specify the instance on the subform or the field ?"
                I think you'll need to get to use DriverLicense to get the count of how many driver licenses you have.
                count(/process_data/xfaform/object/data/xdp/datasets/data/App/DriverLicense)
                then you can have a loop (just a route coming back to a previous step) that get the value using something like:
                /process_data/xfaform/object/data/xdp/datasets/data/App/DriverLicense[i]/drvlicstate
                Jasmin
                • 5. Re: Inserting Multiple instances into a databse
                  HowardTreisman Level 1
                  You can set up a loop as described, or you can do it in a single step using the following custom component:
                  Docs: http://avoka.dnsalias.com/confluence/display/Public/XML+to+SQL+DSC
                  Download: http://www.avoka.com/avoka/escomponents.shtml
                  Howard
