4 Replies Latest reply on Feb 5, 2009 1:20 PM by Jasmin Charbonneau
    multiple processes and accessing data
    cmiller99
      Morning,
      I have created 2 processes within workbench.
      Process A - assigns a form with some data in it to a internal user via workspace, it then sends that form to a outside user via email.
      they are to update/correct any data and email it back. After the send I have an event to wait for process B to recieve the email and process it.
      Process B - start point is a recieve function, it picks up these recieved emails and pulls out the data and puts it into xml.
      My problem is process A has one processID, when process B fires up it gets a different processID. How can I merge the data from process B to process A and allow process A to continue on.
      This is something like the in the samples LIvecycle end-to-end mortgage application, however I don't understand on the data comes back and is married together.
      We thought of creating our own ID in the form however I still run into the same issue when merging the data.
      Am I even performing this correctly?
      Any better ways of doing this?
      How do I do this?
      Carmen
        • 1. Re: multiple processes and accessing data
          Jasmin Charbonneau Level 4
          You have to merge the information manually.
          It won't get merged from one process to another.
          Jasmin
          • 2. Re: multiple processes and accessing data
            cmiller99 Level 1
            and how is that done?
            is their a better way of doing this?
            can "complete task" under process mgt help me in this situation?
            or events and passing the xml? but not sure how to ensure that I am matching the correct processes together.
            Carmen
            • 3. Re: multiple processes and accessing data
              cmiller99 Level 1
              Afternoon,
              If anyone is interested.
              I put the processID into the outgoing form. (could us anything really, just need something unique)
              I ended up writing the xml to the filesystem in a folder based on the processid from the intial process. tossed a event to go back to my existing process that I filtered on to ensure the pid's matched from the throw and the receive. I then read the xml from the file system and continued on with my process.
              Using contentspace would be an option however the client I am working for doesn't have it.
              Thanks.
              • 4. Re: multiple processes and accessing data
                "My problem is process A has one processID, when process B fires up it gets a different processID. How can I merge the data from process B to process A and allow process A to continue on."
                Why can't process B just return the data back to process A. I'm assuming process A makes a call to process B.
                Process A can wait until process B finishes and then get the output parameters from process B which would be you data and then go on.
                Jasmin
