1 Reply Latest reply on Feb 18, 2009 1:06 PM by Steve Bishop
    Insert a DB record and receive the Record ID
      Hi !
      I'm trying to populate a DB (two tables) based
      on the classic master/detail approach.
      These steps represent what I would like to achieve :
      1) add the master record and get the corresponding primary key
      2) add multiple records in another table using the Master Prim.key
      That seems to be so simple,
      but I have no idea how to get the Master PrimaryKey.
      Thanks.
      GB.
        • 1. Re: Insert a DB record and receive the Record ID
          Steve Bishop Level 2
          You can't get a result back from the standard database call. If there is another unique field, you could query again based on that. I needed something with one child record. I did the whole thing in a PL/SQL block passing all the parameters to one call.
          To get a value back from a call, look at this thread: http://www.adobeforums.com/webx/.59b7d6b1/3
