2 Replies Latest reply on Apr 13, 2009 4:16 PM by The Flex Viking
    Flex + Multiple Routes, which button clicked?
    The Flex Viking
      I have a User Task (which uses a Flex form) in workbench which has 2 defined routes leading out of it, Approve and Reject. If Accept, a bunch of validation should occur. If Reject, no validation is needed.
      When the user clicks on either of these buttons in the bottom of Workspace, I receive an event within Flex, which typically kicks of my validations. But, both buttons fire off this event and I don't see any way of telling which of the 2 buttons was clicked.
      Anyone have an idea
        • 1. Re: Flex + Multiple Routes, which button clicked?
          Level 1
          Hello,
          At your PDDF form you have controls loke this : AWS_SUBMIT, AWS_ACTION, AWS_PROCESSTYPE etc.
          AWS_SUBMIT it is button, you can put some javascript code on it's onClick event , which will make youre validation.
          Example:
          prodata.AWS_SUBMIT::click - (JavaScript, client)
          // This is the AWS_SUBMIT click script
          if (xfa.host.name == "Acrobat")
          //validation
          if (prodata.AWS_ACTION.rawValue == "Cancel"){
          data.main.field.validate.nullTest = "";
          if (prodata.AWS_ACTION.rawValue == "Approve"){
          data.main.field.validate.nullTest = "Error";
          • 2. Re: Flex + Multiple Routes, which button clicked?
            The Flex Viking Level 1
            Not using PDFs, using Flex.
            I think the answer is you have to do it yourself.
            1. Only 1 route out of the Assign Task.  This is Complete Task
            2. Create a Decision Point which routes based upon data provided in the XML provided by the form.
