2 Replies Latest reply on Mar 23, 2009 3:33 AM by (kanimambo)
    Email Activity and admin notification
      I have a problem sending emails using email services activity, everytime i try the process stall's but to my surprise the system does not even send me stall action email notification eventhough i have set it up in the adminui. I think i have configured the email activity under components>emailcomponent>activeservices>Sendemailservices 1.0>editservices configuration. and restarted the service but still i don't get any joy.
      Here is the log message from the log file.
      2009-03-19 08:41:19,906 ERROR [com.adobe.workflow.AWS] stalling action-instance: 1201 with message: Incorrect SMTP server provided: java.lang.Exception: Incorrect SMTP server provided
      at com.adobe.livecycle.sample.email.EmailServiceImpl.send(EmailServiceImpl.java:232)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:585)
      at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
      at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
      at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
      at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:342)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:212)
      at sun.reflect.GeneratedMethodAccessor326.invoke(Unknown Source)
      at org.jboss.invocation.Invocation.performCall(Invocation.java:345)
      at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:214)
      at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:149)
      at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:154)
      at org.jboss.webservice.server.ServiceEndpointInterceptor.invoke(ServiceEndpointInterceptor. java:54)
      at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:48)
      at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:106)
      at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:363)
      at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:166)
      at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:153)
      at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:192)
      at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:122)
      at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:624)
      at org.jboss.ejb.Container.invoke(Container.java:873)
      at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:415)
      at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:88)
      at $Proxy169.doSupports(Unknown Source)
      at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:104)
      at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
      at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
        • 1. Re: Email Activity and admin notification
          Jasmin Charbonneau Level 4
          You can configure the service two ways.
          You can configure it the way you did (under Components). But you need to make sure you check the "Use Configuration Options" checkbox in the Connection Settings tab.
          Otherwise you'll need to put the configuration in the email step under Connection Settings.
          Jasmin
          • 2. Re: Email Activity and admin notification
            Level 1
            For some reasons i think the problem is actually bigger than the email action itself, because as the administrator i still dont get Administrator notifications even though i have checked "Enable Stall operation and Enable Stall Branch" check boxes.
            I did as you advised about the email action settings but i'm still getting the following message in my log file:
            2009-03-23 13:26:00,067 WARN [com.adobe.workflow.AWS] com.adobe.idp.dsc.email.SendMailFailedException: 550 5.7.1 Requested action not taken: message refused
            at com.adobe.idp.dsc.email.EmailServiceImpl.sendWithMapOfAttachments(EmailServiceImpl.java:7 38)
            at com.adobe.idp.dsc.email.EmailServiceImpl.sendWithDocument(EmailServiceImpl.java:353)
            at sun.reflect.GeneratedMethodAccessor329.invoke(Unknown Source)
            at $Proxy202.asyncInvokeProcessCommand(Unknown Source)
            at com.adobe.workflow.engine.ProcessCommandControllerBean.doOnMessage(ProcessCommandControll erBean.java:156)
            at org.jboss.mq.SpyMessageConsumer.addMessage(SpyMessageConsumer.java:160)
            at org.jboss.mq.SpySession.run(SpySession.java:333)
            at org.jboss.jms.asf.StdServerSession.run(StdServerSession.java:180)
            at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:748)
            at java.lang.Thread.run(Thread.java:595)
            2009-03-23 13:26:00,161 WARN [com.adobe.workflow.AWS] com.adobe.idp.dsc.email.SendMailFailedException: 550 5.7.1 Requested action not taken: message refused
            2009-03-23 13:26:00,161 ERROR [com.adobe.workflow.AWS] stalling action-instance: 1481 with message: 550 5.7.1 Requested action not taken: message refused
            : com.adobe.idp.dsc.email.SendMailFailedException: 550 5.7.1 Requested action not taken: message refused
            2009-03-23 13:26:00,317 WARN [com.adobe.workflow.AWS] Email failed to send due to the following exception:550 5.7.1 Requested action not taken: message refused
            2009-03-23 13:26:04,177 INFO [STDOUT] 2009/03/23 1:26:04 PM com.adobe.idp.event.util.EventDBHelper getEventByPrimaryKey
            SEVERE: **************************************************************
            SEVERE: Event with id 2315 is already deleted or does not exist.
            2009-03-23 13:26:04,177 INFO [STDOUT] 2009/03/23 1:26:04 PM com.adobe.idp.scheduler.callback.ServiceCallbackHandler execute
            SEVERE: Exception thrown while calling back a DSC componentEvent instance with id 2315 does not exist.
