7 Replies Latest reply on Apr 10, 2009 1:07 AM by wmegel
    Task Attachments
    (jerome_dinnat) Level 1
      Am I right if I think the task attachment of a process are saved in the GDS of the application server ?
      Is there a way to purge the task attachments where there are no more needed ? (even using the java api)
      Because the GDS will grow up to big.
      Thank you.
        • 1. Re: Task Attachments
          JoshDBoyle Level 1
          Jerome
          I don't know if there is any other location that task attachments are stored but I do know that you can find them in the table tb_task_attachments as BLOB entries.
          Josh Boyle
          jboyle@cardinalsolutions.com
          Cardinal Solutions Group
          • 2. Re: Task Attachments
            Hi josh,
            Thanks for the reply. I saw this table but I will explain you my issue.
            In a process, my users need to attach sources to the Workflow. The attachments are next copy in a directory on a server.
            I was wondering what happen if big attachments are added. So I added a zip file from 1Go to the form. The file was good copying in the directory I want and the process terminated good.
            I saw the tb_task_attachments and look at it size. The size is 0.274MB for 73 row. So I think the attachments was saved in an other place. (but I see the [content] blob entries you mentioned. Is the file compressed or a reference to the file ?)
            I checked in the /jboss/server/all/svcnatives/documentStorage and find my file of 1Go in a directory.
            So I am asking me if several users add big attachments, my GDS will grow up to big. How can I delete the attachement from the GDS without delete process instance.
            • 3. Re: Task Attachments
              I read that the big attachments are not stored in the database but in the GDS. There are permanent document so they will never be deleted.
              If I delete them manually or by a Java program, I suppose Livecycle will crashe.
              • 4. Re: Task Attachments
                HowardTreisman Level 1
                Hi Jerome
                We have developed a utility to remove large attachments, and several other LiveCycle data objects that consume database/GDS space.
                You can download a trial here:
                http://www.avoka.com/avoka/addons.shtml - click on "Purge Utility".
                By the way, attachments are stored as "Documents", which mean that they follow the same rules as other types of documents - they are stored in the database till they exceed the threshold (64K by default), and thereafter they are stored in the GDS.
                Howard
                • 5. Re: Task Attachments
                  Hi Howard,
                  I saw your solution, you have a lot of very interesting utilities on your web site but unfortunately I can't use a non-free solution.
                  I try to find an other way to upload files from my user to a folder server.
                  Thanks for the help.
                  • 6. Re: Task Attachments
                    Hi Jerome
                    I found your response very interesting...
                    Without meaning to query your decision, can you explain why you can't use a "non-free solution".
                    It seems to me that you've already spent a lot of money on LiveCycle, so you've already commited to using a "non-free solution".
                    Why not spend a bit more and end up with a solution that solves all your problems?
                    Instead you seem to be about to spend a whole lot of time and effort to come up with a solution for a problem that we've already solved. Isn't your time also worth something? For the record, it took somewhere around a man-month of effort to build the purge tool, by a developer who already had a whole lot of experience with LiveCycle - and you can buy it for the price of a few days of your time.
                    I would very much like to get an understanding of your reasoning, and look forward to your response.
                    Many thanks,
                    Howard
                    • 7. Re: Task Attachments
                      wmegel
                      It's possible to delete attachements with the TaskManager API :
                      TaskManager taskManager = TaskManagerClientFactory.getTaskManager(_Factory);
                      taskManager.deleteAttachment(TaskID, AttchID);
                      I never tested it but suppose that it will delete the document from the GDS.
                      [Update]
                      I've juste tested id and and unfortunately it does not Work !
                      The function only delete the line in the Database but not the document in the GDS!
                      Isn'it a bug ??
                      Will
