3 Replies Latest reply on Feb 13, 2008 2:58 AM by HowardTreisman
    Set Value in PDF Document
    Level 1
      I am submitting a form as a PDF (set within the FSSUBMIT_ button) into a workflow. I was wondering if there is a way to set the value of a field within the form with a simple xPath expression. I know that I can access those fields by stripping out the xml with the processFormSubmission service but I wouldnt think I can set any fields as they are then put into a separate XML var. The reason Im submitting as a PDF is to hold the values of signature fields. If anyone knows a solution, I would appreciate it.
