5 Replies Latest reply on Feb 11, 2008 3:06 AM by HowardTreisman
    Email Endpoint - Output parameters
      I've a problem with the configuration of the outputs parameters of my email endpoint.
      To begin, here's a short description of what I'm trying to do:
      1. A user send an email (without attachment) with an order number in the subject to the system.
      2. The system generates a PDF based on the order number sent by the user.
      3. The system send a response email with the generated PDF in the attachments.
      Everything is working very well for the points 1 and 2, my PDF is generated, I've used the variable logger to check those points.
      Correct me if I'm wrong but I think that the email endpoint wait for a response at the end of the process and send the result to the user.
      I've created a Document variable with the OUT option checked. My generated PDF is loaded into this variable.
      But here's my problem: Whatever params I put in the email endpoint output parameters settings an error is sent to my email:
      "No results after invocation. It could be a problem during invocation."
      I've tried to use a binary variable instead of the Document one and the result is slightly different:
      The email doesn't contain an error but there isn't any attachment.
      Here's some parameters I've tried for the output mapping params:
      Thanks in advance for your help.
