I want to use form guides for user form filling, but also the resultant PDF form must be digitally signed. I'm presenting the form inside Workspace and as a part of workflow.
I've read Form Guides Getting Started document. There, it uses xfaForm type input variable for the process. As I know, xfaForm is data only. So it doesn't work when signatures are needed. I've tried to change the variable type to documentForm in the Sample Mortgage Loan Flex process, but with again no success. This time, on the second step of process, the form rendering on Workspace gave an error as follows:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at MethodInfo-11871()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.core::UIComponent/dispatchEvent()
at mx.core::UIComponent/set initialized()
at mx.managers::LayoutManager/doPhasedInstantiation()
at Function/http://adobe.com/AS3/2006/builtin::apply()
at mx.core::UIComponent/callLaterDispatcher2()
at mx.core::UIComponent/callLaterDispatcher()
To sum up: Can we use form guides for filling out forms that are to be digitally signed and sent to the next step in the process?
Thank you
