Expand my Community achievements bar.
Program Workspace for Specific Acrobat Reader Version
Avatar
Former Community Member
I am using LC ES 8.0.
Is there a way to program Workspace to use a specific version of Reader? I want it to open Acrobat Reader version 8 or higher.
We have a few problems with some other older software that several hundred users are using and it requires them to use Acrobat Standard v6. I want to push Reader 8 to everyone and can specify that Standard or Pro are default if available but I want to make Workspace specifically use Reader version 8 or higher.
Does anyone know if this can be done programatically in Workspace?
John
Avatar
Level 2
Once way to do it is if the process you are invoking uses the Render PDF Form, or a custom Render process that includes the renderPDFForm operation (from the Forms service), you can change a setting using the Acrobat Version property to Acrobat and Adobe Reader 8 or later.
You can get more details about the renderPDFForm operation and the Acrobat Version property at http://livedocs.adobe.com/livecycle/8.2/wb_help/000614.html.
Hope that helps!
Avatar
Level 9
The only reliable way to do it is to add Javascript into your form.
Howard
http://www.avoka.com
