Expand my Community achievements bar.
Cannot login to workspace when using https only
Avatar
Level 4
I have installed LC server in our production environment and the only enabled port to connect it throught firewall is 443 for https. I have configured JBoss / tomcat to use certificate and listen on the https port. Now I can connect to https://servername/workspace well, but cannot log in. After entering username/password the flex app wait. Using network monitor revealed that workspace tries to connect to http://servername on port 80, not 443. Where can I change it? Where can I specify server hostname and port?
Thank for your help.
--- Jaroslav
Avatar
Level 3
Hi, Checked with the team and they know this works in 8.2.1SP1 or 8.2.1.SP2. What version are you using. Also are you using a manually configured App Server or TurnKey JBoss.
Thanks.
Gary.
Avatar
Level 4
Hi, it is version 8.2. I found and applied security quick fix from Adobe support web site. It solved the problem.
--- Jaroslav
Avatar
Former Community Member
I am having this problem while running the following version:
Version: 8.2.1, GM
Patch Version: SP1
Service Pack Version: 8.2.2287.2.189966.1
My App Server is WebSphere.
Also, I see a reference to a 8.2.1.SP2, but I can't find the download
location for 8.2.1 SP2.
John.
Avatar
This sounds similar to a problem we are having. It occurs with a custom workspace only though. We only changed the logo. Also on 8.2.1, SP1, but on JBoss.
