Expand my Community achievements bar.
Error while using LiveCycle java APIs with Http servlets:"Remote EJBObject lookup failed for ejb/Inv
Avatar
Level 1
Hi all,
When i try to run more than one servelt of the Quick Start samples that using Livecycle Java APIs and i get an error of "Remote EJBObject lookup failed for ejb/Invocation provider" from any servelt i run.
I try some Quick samples which is not servelts (java class) and it works fine, which makes me sure that my connection properties is true.
Environment:
The LiveCycle is based on "Websphere v6.1", and i use "Eclipse Platform
Version: 3.4.1".
i install "tomcat 5.5.17" to test the servelts in developing time through Eclipse.(only for test in developing time not for deploy on )
The Jars i added in the classpath:
adobe-forms-client.jar
adobe-livecycle-client.jar
adobe-usermanager-client.jar
adobe-utilities.jar
ejb.jar
j2ee.jar
ecutlis.jar
com.ibm.ws.admin.client_6.1.0.jar
com.ibm.ws.webservices.thinclient_6.1.0.jar
server.jar
utlis.jar
wsexception.jar
My code is :
Properties ConnectionProps = new Properties();
ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT, "iiop://localhost:2809");
ConnectionProps.setProperty ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL,ServiceClientFactoryProperties.DSC_EJB_PROTOCOL);
ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE,ServiceClientFactoryProperties.DSC_WEBSPHERE_SERVER_TYPE);
ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, "Administrator");
ConnectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, "password");
ConnectionProps.setProperty("java.naming.factory.initial", "com.ibm.ws.naming.util.WsnInitCtxFactory");
//Create a ServiceClientFactory object
ServiceClientFactory myFactory = ServiceClientFactory.createInstance(ConnectionProps);
//Create a FormsServiceClient object
FormsServiceClient formsClient = new FormsServiceClient(myFactory);
//Get Form data to pass to the processFormSubmission method
Document formData = new Document(req.getInputStream());
//Set run-time options
RenderOptionsSpec processSpec = new RenderOptionsSpec();
processSpec.setLocale("en_US");
//Invoke the processFormSubmission method
FormsResult formOut = formsClient.processFormSubmission(formData,"CONTENT_TYPE=application/pdf&CONTENT_TYPE=application/vnd.adobe.xdp+xml&CONTENT_TYPE=text/xml", "",processSpec);
List fileAttachments = formOut.getAttachments();
Iterator iter = fileAttachments.iterator();
int i = 0 ;
while (iter.hasNext()) {
Document file = (Document)iter.next();
file.copyToFile(new File("C:\\Adobe\\tempFile"+i+".jp i++;
short processState = formOut.getAction();
...... (To the end of the sample)
My Error was:
com.adobe.livecycle.formsservice.exception.ProcessFormSubmissionException: ALC-DSC-031-000: com.adobe.idp.dsc.net.DSCNamingException: Remote EJBObject lookup failed for ejb/Invocation provider
at com.adobe.livecycle.formsservice.client.FormsServiceClient.processFormSubmission(FormsServiceClient.java:416)
at HandleData.doPost(HandleData.java:62)
at HandleData.doGet(HandleData.java:31)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
a
Avatar
Former Community Member
I assume here that your application is deployed on a different physical machine of where LCES is deployed and running.
Do the following test:
- Say that LCES is deployed on machine1 and your application is deployed on machine2. Ping machine1 from machine2 and note the ip address.
- Ping machine1 from machine1 and note the ip address.
The two pings should match.
- Ping machine2 from machine1 and note the ip address.
- Ping machine2 from machine2 and note the ip address.
Usually this kind of error would happen if your servers have internal and external ip addresses.
Avatar
Level 1
Hi pierre ,
thanks for your replay.
But i tried this code on the same physical machine that LCES exists.
as i installed LCES ,Webshpere application server ,databse server and Eclipse on the same machine.
and this errors only appears when trying to run the servelt ,but when i try to run the same code with java Class( with main) and run as java application it works fine .
Any Help is highly Appreciated.
