10 Replies Latest reply on Sep 17, 2015 8:26 AM by ADEL_CAP
    GeneratePDFOutput ends with a Stall
      Hello,
      I've created a process that runs the GeneratePDFOutput service that creates a PDF document by merging Form/Data. The process works fine and the PDF document gets genetrated, but the GeneratePDFOutput step ends with a Stalled condition. The error is:
      ALC-DSC-305-000: com.adobe.idp.dsc.transaction.MarkedForRollbackException: The current transaction has been marked for rollback. This means one of three things; 1) this transaction has timed-out (the timout period was set to [180(sec)], while the actual tx took [359(sec)]), 2) And unhandled Runime exception occurred when calling another service (please check the logs for more detail, or 3) This is a JTA transaction and a service has explicitly marked a transaction for rollback.
      The GeneratePDFOutput is the last step in the process. What am I doing wrong? How do I prevent the step from Stalling?
      Thanks in advance,
      Hope
        • 1. Re: GeneratePDFOutput ends with a Stall
          Jasmin Charbonneau Level 4
          Is it a short lived or long lived process?
          You can check under the process properties under advanced.
          There are also transaction settings you can play with to see if that makes any difference.
          Jasmin
          • 2. Re: GeneratePDFOutput ends with a Stall
            Level 1
            I am facing similar issues with generatePDF(Output Service: this is called as an API: OutputClient).
            I am set the websphere's timeout to max and even then I get these errors:
            ALC-DSC-305-000: com.adobe.idp.dsc.transaction.MarkedForRollbackException: The current transaction has been marked for rollback. This means one of three things; 1) this transaction has timed-out (the timout period was set to [180(sec)], while the actual tx took [6(sec)]), 2) And unhandled Runime exception occurred when calling another service (please check the logs for more detail, or 3) This is a JTA transaction and a service has explicitly marked a transaction for rollback
            I have tested my installation and it works for sure(since I have tried it with other code and used the same service),
            There is just one more thing, suppose I give a false form name(ie a form name that does not exist); then I am getting the right error message :Failed to load TemplateStream for FormQuery=LIKE.xdp from location.
            Any suggestions/solutions?
            regards,
            Sushant
            • 3. Re: GeneratePDFOutput ends with a Stall
              Ruytero Level 1
              I'm facing the same problem, anybody have a solution for this?
              Regards
              • 4. Re: GeneratePDFOutput ends with a Stall
                I have the same error when processing big data files. Small data files get processed without any problem.
                So, how can i increase the timeout time?
                • 5. Re: GeneratePDFOutput ends with a Stall
                  Is there a way to disable timeout?
                  http://www.layeronline.com
                  • 6. Re: GeneratePDFOutput ends with a Stall
                    In adminui go under Home > Services > Applications and Services > Service Management and search for OutputService.
                    Then click on it and change the transaction timout.
                    Jasmin
                    • 7. Re: GeneratePDFOutput ends with a Stall
                      HowardTreisman Level 1
                      You may also need to change the transaction timeout in the properties dialog for your orchestration (in Workbench).
                      Howard
                      http://www.avoka.com
                      • 8. Re: GeneratePDFOutput ends with a Stall
                        Hi Hope
                        I'm getting the same error, and I want to isolate the problem. Could you provide me some information on your environment (which produced this problem) by answering the questions below.
                        1) What LiveCycle version were using (was it 8.2)?
                        2) What OS (Windows 2003 ?)
                        3) What App Server were you using?
                        4) What Database were you using?
                        Ben
                        • 9. Re: GeneratePDFOutput ends with a Stall
                          Jaroslav Pavlicek Level 1
                          This helped me now. Thank You a lot for write it here.
                          --- Jaroslav
                          • 10. Re: GeneratePDFOutput ends with a Stall
                            ADEL_CAP
                            I have exactly the same error, can anybody help us?
                            ERROR [com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean] (WorkManager(2)-31) The current transaction has been marked for rollback.
                            1) This transaction has timed-out (the timeout period was set to [600(sec)]600, while the actual transaction took [608(sec)]),
                            2) An unhandled exception occurred when calling another service (please check the logs for more detail), or
                            3) This is a JTA transaction and a service has explicitly marked this transaction for rollback
                            ALC-DSC-305-000: com.adobe.idp.dsc.transaction.MarkedForRollbackException: La transaction actuelle a été marquée pour la restauration.
                            Cela implique lune des trois choses suivantes :
                            1) La transaction a expiré (le délai dexpiration était défini sur [600(sec)] alors que la transaction réelle a duré [608(sec)]),
                            2) Une exception dexécution non prise en charge sest produite lors de lappel dun autre service (pour plus de détails, consultez les journaux), ou
                            3) Il sagit dune transaction JTA et ce service a explicitement marqué la transaction pour la restauration.
                            Thx.
