0 Replies Latest reply on Feb 14, 2008 12:59 PM by rveldpau
    Component Development Helper
    rveldpau
      I found that creating the Component.xml file to be quite annoying, so I wrote a quick VB.Net application (Framework 2.0) to help create the major portions of it.
      The program creates 4 major things.
      <ol>
      <li>Service Node - This is the most important one, it creates an entire service node based on your implementation class.</li>
      <li>Composite Editor Node - This generates a composite editor based on all protected variables listed.</li>
      <li>Java Accessors - This actually generates Java code so that you don't have to create all the annoying Java Access methods.</li>
      </ol>
      To download the program go to:
      http://rsvisuals.com/otherStuff/ComponentHelper.zip
      Hope this helps you out, I provide no support if it doesn't work, i just don't have the time.
