0 Replies Latest reply on Sep 17, 2008 4:06 AM by Akulaa Jain
    Known Issues - Enrollment SA
    Akulaa Jain
      b Dynamic Document Generator (DDG)
      i Problem:
      When you deploy DDGSample.war, and try to run the samples,the following exception occurs -
      [javax.servlet.ServletException: com/adobe/idp/um/businesslogic/authentication/AuthenticationToken
      org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:848)
      org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:781)
      org.apache.jsp.orderInteractive_dxfa._jspService(org.apache.jsp.orderInteractive_dxfa:79) ]
      i Solution:
      1. Undeploy the existing DDGSample.war
      2. Replace the "DDGSample.war\WEB-INF\lib\adobe-usermanager-client.jar" with your LiveCycle Installation's adobe-usermanager-client.jar (LiveCycle ES Update1)
      3. Redeploy the updated DDGSample.war
      b Approval Workflow Sample
      i Problem:
      When running the Approval Workflow Sample,errors regarding the SDI exception in the SolutionAcceleratorInvocationService and that the testservice not found appear.
      2008-08-25 11:15:53,768 INFO  [STDOUT] org.springframework.beans.factory.parsing.BeanDefinitionParsingException: Configuration problem: Bean class [com.adobe.solutions.testservice.TestServiceImpl] not found
      Offending resource: resource loaded through InputStream
      Bean 'testService'; nested exception is java.lang.ClassNotFoundException: JMS SessionPool Worker-3Class name com.adobe.solutions.testservice.TestServiceImpl from package com.adobe.solutions.testservice not found.
      i Solution:
      Remove the following line from sdi.xml asset.
