2 Replies Latest reply on Sep 2, 2009 12:49 PM by Varma_LC
    Problem with XML encoding while using DDG
    Badri Lakshminarasimhan
      I have a submit button in a PDF that submits the PDF data in UTF-8 encoded XML format. The PDF hame rich text fields. Hence the XML contains some characters like à which is a valid UTF-8 character.
      When I try to recreate the PDF using this XML and the same template used to construct the PDF, the DXFA file is throwing the following exception.
      Is there a way I can specify to the DXFA the character set of the XML?
      Invalid byte 2 of 2-byte UTF-8 sequence.
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R org.xml.sax.SAXParseException: Invalid byte 2 of 2-byte UTF-8 sequence.
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.adobe.solutions.utils.XMLUtils.initDocument(XMLUtils.java:920)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.adobe.solutions.utils.DOMPlus.init(DOMPlus.java:140)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.adobe.solutions.utils.DOMPlus.load(DOMPlus.java:101)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.adobe.solutions.generatedoc.utils.Utils.getDatasetsNode(Utils.java:344)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.adobe.solutions.generatedoc.utils.Utils.renderFormsDoc(Utils.java:294)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.adobe.solutions.generatedoc.utils.Utils.renderOutputDoc(Utils.java:285)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.adobe.solutions.generatedoc.RenderTag.doAfterBody(RenderTag.java:78)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.ibm._jsp._templatestitcherflat_5F_dxfa._jspService(_templatestitcherflat_5F_dxfa.java :206)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.ibm.ws.jsp.runtime.HttpJspBase.service(HttpJspBase.java:87)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
      [2/17/09 8:30:17:798 EST] 0000003a SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1096)
