6 Replies Latest reply on Sep 1, 2008 6:17 AM by Johannes Lehninger
    DDGWebSample - Error
    Johannes Lehninger Level 1
      I've deployed everything following your guide but I get the listed error as click Generate Document on http://host:8080/DDGSample/orderInteractive.html
      there is no AuthenticationToken class in the adobe_usermanagement_client.jar file.
      Any ideas?
      regards
      Johannes
      javax.servlet.ServletException: com/adobe/idp/um/businesslogic/authentication/AuthenticationToken
      org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:848)
      org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:781)
      org.apache.jsp.orderInteractive_dxfa._jspService(org.apache.jsp.orderInteractive_dxfa:79)
      org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97)
      javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
      org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:322)
      org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
      org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
      org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:81)
        • 1. Re: DDGWebSample - Error
          Can you try replacing the adobe-usermanager-client.jar with the {LC_Install_Directory}\LiveCycle_ES_SDK\client-libs\common\ adobe-usermanager-client.jar on your machine. The problem seems to be with different versions of adobe-usermanager-client.jar
          http://www.adobeforums.com/webx/?13@@.59b64d80
          • 2. Re: DDGWebSample - Error
            thx, I've replaced the jar file, but the error is still the same and the archive does not contain the AuthenticationToken Class.
            other ideas?
            regards
            Johannes
            root cause
            java.lang.NoClassDefFoundError: com/adobe/idp/um/businesslogic/authentication/AuthenticationToken
            java.lang.ClassLoader.defineClass1(Native Method)
            java.lang.ClassLoader.defineClass(ClassLoader.java:620)
            java.security.SecureClassLoader.defineClass(SecureClassLoader.java:124)
            org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:162 9)
            org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:850)
            org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1299)
            org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1181)
            java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
            java.lang.Class.getDeclaredMethods0(Native Method)
            java.lang.Class.privateGetDeclaredMethods(Class.java:2395)
            java.lang.Class.privateGetPublicMethods(Class.java:2519)
            java.lang.Class.getMethods(Class.java:1406)
            com.adobe.solutions.generatedoc.utils.Utils.getMethod(Utils.java:852)
            com.adobe.solutions.generatedoc.RenderTag.setPageContext(RenderTag.java:77)
            org.apache.jsp.orderInteractive_dxfa._jspx_meth_lc_render_0(org.apache.jsp.orderInteracti ve_dxfa:92)
            org.apache.jsp.orderInteractive_dxfa._jspService(org.apache.jsp.orderInteractive_dxfa:70)
            • 3. Re: DDGWebSample - Error
              Level 1
              Have you replaced the adobe-usermanager-client.jar in DDGSample.war\WEB-INF\lib and redeployed the war file ?
              If yes , please tell the value of Specification-Version
              property from the adobe-usermanager-client.jar\META-INF\MANIFEST.MF file.
              • 4. Re: DDGWebSample - Error
                hi,
                here the Specification-Version
                Specification-Version: 8.2.2164.1.183592.1
                regards
                Johannes
                • 5. Re: DDGWebSample - Error
                  Level 1
                  Ok. First replace the "DDGSample.war\WEB-INF\lib\adobe-usermanager-client.jar" with your adobe-usermanager-client.jar (Specification Version 8.2.2164.1.183592.1 ) and redeploy the DDGSample.war.
                  For redeployment you need to undeploy the previous DDGSample.war WebApp and then deploy the new DDGSample.war (with the replaced adobe-usermanager-client.jar). It should work.
                  • 6. Re: DDGWebSample - Error
                    thx
                    now it works!
                    regards
                    Johannes
