1 Reply Latest reply on Sep 2, 2008 9:45 AM by StefCameron
    Problem logging into the cmContentCreator application
    Level 1
      I am having issue logging into the cmContentCreator application that is part of the correspondence management solution accelerators. The issue I am running into, is that I can enter user name and password. However when I click on the Login button, nothing happens. I have checked the server log, and there's no indication that an attempt to login even occurs. I even try to use password that will fail, but still get no response.
      The weird part is, if I try to launch the swf from the jboss\server\all\tmp directory, I am able to login fine after updating the server info.
      The build i got is dated August 20th, 2008. The war is dated August 16th, 2008.
      Thanks for your help in advance.
      David
      www.ensemble.com
