1 Reply Latest reply on Apr 14, 2007 5:55 PM by (Nick_Suvalko)
    Print existing PDF in central
      We are currently using Adobe Central Server and we need to somehow print an existing PDF and incorporate this to the Central server.
      Is there a program that is shipped with central that I can use?
      Thanks in advance.
        • 1. Re: Print existing PDF in central
          You can do it with the following script after downloading a freeware program called "pdfp" which can print PDF's silently in background.
          However I can not get it to execute via Custom Agent by executing a TASK. The log says it executes the task but the no output is generated.
          However when I click the BAT or EXE file I create it's fine????
          Can someone help... here are contents of ini files etc.
          Thank you in advance.
          OUTPUT FROM JFSERVER LOG FILE
          2007/04/15 11:48:08 C:\Program Files\Adobe\Central\Bin\jfserver.exe: [306]Processing file 'Account_Confirmation_Letter_14935.dat', '^job tnewcust.fx'.
          2007/04/15 11:48:08 C:\Program Files\Adobe\Central\Bin\jfserver.exe: [307]Launching task '"C:\Program Files\Adobe\Central\Bin\jfmerge" "C:\CENTRALPRO_FORMS\testmdf\NCTESTP.mdf" "C:\Program Files\Adobe\Central\Server\Data\Account_Confirmation_Letter_14935.dat" -l -apr"" -all"C:\Program Files\Adobe\Central\Server\jfserver.log" -asl1 -amq0 -ams"C:\Program Files\Adobe\Central\Server\Mst\AKL27.mst" -m1T -argon -z"\\192.168.2.10\akl27" -aii"C:\Program Files\Adobe\Central\Server\jfmerge.ini"'.
          2007/04/15 11:48:08 C:\Program Files\Adobe\Central\Bin\jfmerge: [125]* Processing data file: 'C:\Program Files\Adobe\Central\Server\Data\Account_Confirmation_Letter_14935.dat'.
          2007/04/15 11:48:08 C:\Program Files\Adobe\Central\Bin\jfmerge: [289]MDF file `C:\CENTRALPRO_FORMS\testmdf\NCTESTP.mdf' opened.
          2007/04/15 11:48:08 C:\Program Files\Adobe\Central\Bin\jfmerge: [209]One surface was printed.
          2007/04/15 11:48:08 C:\Program Files\Adobe\Central\Bin\jfserver.exe: [307]Launching task '"C:\Program Files\Adobe\Central\Bin\ncustprt" '.
          2007/04/15 11:48:09 C:\Program Files\Adobe\Central\Bin\jfserver.exe: [308]Sleeping for 5 seconds.
          2007/04/15 11:48:14 C:\Program Files\Adobe\Central\Bin\jfserver.exe: [305]Scanning for data files, directory 'C:\Program Files\Adobe\Central\Server\Control\'.
          2007/04/15 11:48:14 C:\Program Files\Adobe\Central\Bin\jfserver.exe: [305]Scanning for data files, directory 'C:\Program Files\Adobe\Central\Server\Data\'.
          2007/04/15 11:48:14 C:\Program Files\Adobe\Central\Bin\jfserver.exe: [306]Processing file 'Account_Confirmation_Letter_24936.dat', '^job tnewcust.pdf'.
          THESE ARE THE OTHER DETAILS FROM THE INI FILES
          jfserver.ini
          [Processes]
          JFSERVER=Central Process
          JFEMSEND=Messaging Agent
          JFMERGE=Print Agent
          JFPVAGENT=Preview Agent
          JFTRANS=Transformation Agent
          XMLIMPORT=XML Import Agent
          NCUSTPRT=New Customer PDF Output
          [JFEMSEND]
          ExePath=C:\Program Files\Adobe\Central\Bin
          IniFileName=C:\Program Files\Adobe\Central\Server\jfemsend.ini
          EditCfgRtn=notepad C:\Program Files\Adobe\Central\Server\jfemsend.ini
          [JFMERGE]
          IniFileName=C:\Program Files\Adobe\Central\Server\jfmerge.ini
          [JFPVAGENT]
          IniFileName=C:\Program Files\Adobe\Central\Server\jfpvagent.ini
          EditCfgRtn=Notepad C:\Program Files\Adobe\Central\Server\jfpvagent.ini
          [JFTRANS]
          IniFileName=C:\Program Files\Adobe\Central\Server\jftrans.ini
          EditCfgRtn=notepad C:\Program Files\Adobe\Central\Server\jftrans.ini
          [XMLIMPORT]
          EditCfgRtn=Notepad C:\Program Files\Adobe\Central\Server\xmlimport.xci
          IniFileName=C:\Program Files\Adobe\Central\Server\xmlimport.xci
          [NCUSTPRT]
          IniFileName=C:\Program Files\Adobe\Central\Server\ncustprt.ini
          EditCfgRtn=Notepad C:\Program Files\Adobe\Central\Server\ncustprt.ini
          JMD ENTRIES
          !f newcust.fx FXLASER C:\CENTRALPRO_FORMS\mdf\NEWCUSTP.mdf * 1 T NCXMERGE * * C "Print New Customer Form on Fuji Xerox"
          !f newcust.fx * * * 1 T NCUSTPRT * * C "Print static PDFs for New Customers - CUSTOM Agent"
          !x NCUSTPRT * ncustprt * "Print PDF Documents for new customers"
          SCRIPT TO RUN PDF PRINT IN COMMAND MODE.
          REM ======================================================================================
          REM - Print PDF files to DEFAULT "akl27" printer
          REM
          REM CUSTOM AGENT Created by: Nick Suvalko
          REM Date: 26/02/2007
          cd c:\pdfprint
          pdfp.exe -o 1 -d 1 -c 1 "C:\STATIC_PDF\Claims_Process.pdf"
          pdfp.exe -o 1 -d 1 -c 1 "C:\STATIC_PDF\Conditions_of_Carriage.pdf"
          pdfp.exe -o 1 -d 1 -c 1 "C:\STATIC_PDF\Terms_of_Credit.pdf"
          pdfp.exe -o 1 -d 1 -c 1 "C:\STATIC_PDF\Authority_to_Email_Invoice-Statements.pdf"
          pdfp.exe -o 1 -d 1 -c 1 "C:\STATIC_PDF\PBT_Freight_Calculation_Guideline.pdf"
