0 Replies Latest reply on Apr 19, 2007 1:54 PM by Rubi Tuesday
    xmlimport processing limitation
    Rubi Tuesday Level 1
      Currently I'm trying to run an xml document through central server via the xmlimport and have come up against a problem. It seem that there is a problem processing large files. The file i'm trying to process is 187mb in size. When it is converting the file to .dat format it starts loading the xml in memory, then after a while it crashes and gives an error with no error description. The exact same process is used on smaller files i.e. 100mb, 130mb and works correctly.
      Just curious if anyone has come across this before and if so, how do i get around this without changing the size of the file.
      Regards
      Matt
