1 Reply Latest reply on Dec 13, 2007 10:02 AM by (Tom_Warfield)
    Print directly encrypted PDF on UNIX
      Hello,
      Do you know how to generate directly ENCRYPTED PDF file on a UNIX output queue ? It would generate PDF proctected against modification.
      Thanks for your help.
      K.
        • 1. Re: Print directly encrypted PDF on UNIX
          Level 1
          My manual (Windows, version 5.6) indicates that by default modification is not allowed
          b if
          the PDF security feature is turned on. This is turned on by including the -apdflockyes parameter for the PDF creation task. It can also become permanently activated by setting the
          b Lock
          setting in the
          b [PDFPrep]
          section of the Print Agent configuration file,
          b jfmerge.ini
