3 Replies Latest reply on Nov 11, 2008 6:30 AM by Newsgroup_User
    Possible to share data between classes?
    ibmaris
      I have a panel that uses a local SQL database to display some information from one searchable table. Now I want to add on a button to display more informaton on another panel from a different SQL table, but it is related to the information on the first panel which will still be open. How can I pass the key field from one panel to the other so that it shows the correct data? I have each working independently, just can't get coordinated. I've imported both classes on both panels. When I try to "join" the panels on the key field, I get no data in the second panel. Thanks for any suggestions.
        • 1. Re: Possible to share data between classes?
          Level 7
          "ibmaris" <webforumsuser@macromedia.com> wrote in message
          news:gfag28$h39$1@forums.macromedia.com...
          >from
          > informaton
          > the key
          > have
          > I get
          http://www.magnoliamultimedia.com/flex_examples/Amys_Flex_FAQ.pdf
          Q3
          • 2. Re: Possible to share data between classes?
            ibmaris Level 1
            Thank you, Amy. I took a quick read, and I believe this is just what I needed. Thanks for including the links to more information in your FAQ. It's hard to know where to find information when just starting out. I very much appreciate your help!
            Maris
            • 3. Re: Possible to share data between classes?
              Level 7
              news:gfbsf5$eq7$1@forums.macromedia.com...
              > needed.
              > to
              > appreciate
              > your help!
              You're welcome :-)
