1 Reply Latest reply on May 19, 2005 8:04 AM by (Andrew_Purdy)
    multilingual using OutputServer
      How to create multilingual .dat file or XML file and
      generate PDF report using Output Server.
      Necessary setting which are to be done in the server side
      and the client input file
      thanks in advance
        • 1. Re: multilingual using OutputServer
          Level 1
          To create a multilanguage template, you must ensure that all the boiler plate text are global text substitution.
          Then in your data, you must work out the language that you wish to use, and with a ^file command insert that data file that holds the specified language data.
          this works quite well, but please be aware of different size words when using German, or Italian for example
