1 Reply Latest reply on Nov 12, 2008 8:02 AM by (Tom_Warfield)
    Field-Nominated Transformation Definition Files
      Is it possible to pass a ^job card through the transformation agent when the input file format is field-nominated? Our input file includes a ^job card on line one. Transformation agent is used to manipulate the input data and creates the field-nominated output file for the merge agent. However, the ^job card is missing and is needed for down line processing.
      Thank you
        • 1. Re: Field-Nominated Transformation Definition Files
          Level 1
          I doubt if you will be able to accomplish what you want without a radical change to your file. The "purpose" of the ^job statement is to let Central know what "job" (and therefore the tasks to run) is to be done with the file. The information on the ^job statement is then available as parameters to each task by using variables.
          The best you will likely be able to do is to repeat the ^job information as part of the data and then use the transformation agent to select it and place it all as a variable in the output file.
