1 Reply Latest reply on Dec 9, 2008 2:02 PM by (Brad_Schroeder)
    Problem occuring in one environment and not another
      I am working on a problem we have in our production environment and not our test environment. The page numbers are showing up as 1 of ? in production, which was working in our test environment. Cannot determine why this is happening and could use some help.
      Here is info from the log file
      2008/12/09 08:06:03 e:\Applications\Central\Bin\jfmerge: [179]Possible variable substitution ignored. Variable 'PageCountForFDTrans_1' not found.
      2008/12/09 08:06:03 e:\Applications\Central\Bin\jfmerge: [400]^define User:PageCountForFDTrans_1 1
      Do not see this in the test logs, so looks like we are missing some setup. We did not do this change, but had to take over the maintenance and are now supporting it, so not familiar with what they did.
      Here is the PREAMBLE from the form
      ^comment ************************************************************************************
      ^comment * NOTE. Because the custom properties JFPREAMBLE_n
      ^comment * will be overwritten when you compile you should
      ^comment * apply your preamble overrides to the JFPREAMBLE
      ^comment * custom property following the reference to the
      ^comment * ^FILE DOCVAR:JFPREAMBLE_1 DICTIONARY below.
      ^comment * Preamble overrides...
      ^define user:TransCount 0
      ^define group:!IncrTransCount \defineresolve:TransCount,'@("@:TransCount."+1).'.
      ^define global:Page_Num @$page. of @:PagesInTrans.
      ^define user:PagesInTrans @(If("@:PageCountForFDTrans_@:TransCount.." == 0, "?", "@:PageCountForFDTrans_@:TransCount..")).
      ^define group:!NewPage1 \$page1\defineresolvegroup:!NewPage1,"\page1\$page1.".
      ^define group:!TrcPgCnt \trace"^define User:PageCountForFDTrans_@:TransCount. @$page.@LF.".
      ^comment *
      ^comment *
      ^comment * Do this at the beginning of every transaction
      ^comment * Extend if necessary to do other initializations
      ^comment *
      ^define group:BeginTrans \group!IncrTransCount\group!BeginTrans1.
      ^define group:!BeginTrans1 \group!NewPage1.
      ^comment *
      ^comment *
      ^comment * Do this at the end of every transaction and at end-of-file
      ^comment * Add any per transaction wrap-up you need here.
      ^comment *
      ^define group:EndTrans @(If("@:TransCount." == 0, "", "\group!EndTrans1.")).
      ^define group:!EndTrans1 \group!TrcPgCnt.
      ^comment *
      ^comment *
      ^comment * The !OnEntry event of the major subform/group for a transaction
      ^comment * should invoke !BeginTrans
      ^comment *
      What would be have been setup in our test environment that we missed when moved to our production environment? Thanks
