1 Reply Latest reply on Jan 13, 2009 6:00 AM by (Tom_Warfield)
    Multiple subdirectories under the collector directory
      Hi!
      I am quite new to this product (central pro output server). Is there a way to have central scan data from multiple directories? Or is scanning limited to predefined collector directory?
        • 1. Re: Multiple subdirectories under the collector directory
          Level 1
          Central scans only a single collector folder. Having said that, you can install multiple instances of Central on the same server and each instance will scan a unique folder. By default, each instance will have unique control files and job management database but all will be using a common "bin" folder for the "agents". With work, this can be customized so that one or all instances use a unique "bin" folder and/or use common control files.
