10 Replies Latest reply on Apr 25, 2012 5:55 PM by wryans
    Sending Fax via EMail
      Hello,
      Is it possible to send Fax Number via Email through Output Server to MS Exchange? I get the "Underlying mail system has reported problems in accessing post office" error when I try. We can send Fax Number via Outlook no problem. thanks, C.
        • 1. Re: Sending Fax via EMail
          Level 1
          I am a little unclear what you are trying to accomplish. If you are trying to send a fax, that is a separate functionality than sending an email. Have a look at the presentment target list to see the supported fax servers and review the ^fax command in the print agent reference manual.
          • 2. Re: Sending Fax via EMail
            Level 1
            Hi Chris, I want to send a Fax via the Email process. It is possible in Outlook to send an Email to a Fax Server and have it send. In Outlook for the "Email To" we enter ['faxservername':'phone number'] which upon sending then prints to the designated fax number. I am not sure if it is a No Go or a Configuation Issue on the Output Server. Thanks, Cameron.
            • 3. Re: Sending Fax via EMail
              GuyPhempoompanitch
              Hi Cameron,
              Did you find a solution to this?  I am having the same problem.  Thanks!
              • 4. Re: Sending Fax via EMail
                Michelle_Hanson
                Hi all,
                I use to send faxes from my email. All you have to do is purchase an account from a internet fax provider (i bought from popfax). All you have to do is to configurate your mail agent (such as outlook) and insert the mail of the company, the security code , attach the file and write the numbers (up to 500 of numbers)
                • 5. Re: Sending Fax via EMail
                  KCMcCann
                  Michelle_Hanson wrote: Cheapest Business VoIP Phone Inexpensive Online Fax
                  Hi all,
                  _______________________________________________________________________
                  We've used several email fax companies as well and it is a convenient way to email if you don't mind scanning everything first and for many files,if they contain personal info or confidential email, you need to password protect before you can email.  So in many way, a regular fax is more time efficient.
                  • 6. Re: Sending Fax via EMail
                    cliffdodger
                    The syntax I've seen is phonenumber@yourfaxprovider.com if you're using an online fax provider. Personally I use Metrofax for an email fax service. Also there's a new online fax review site called http://www.faqsaboutfax.com worth looking at.
                    For a local fax server I'd think one's IT department should have the correct info.
                    • 7. Re: Sending Fax via EMail
                      lanceriter
                      removed
                      • 8. Re: Sending Fax via EMail
                        Dturner1122
                        We've been using an online fax service for awhile now and it works pretty smoothly through email. With FaxitFast.com, the service is entirely web based, so sending faxes is as easy as composing a new email and inserting the fax recipient's number as the address, i.e. 3054447755@faxitfast.com and attach any files you want to be faxes (I'm pretty sure FaxitFast lets you attach up to 10 files per outbound fax). I've been using them for a little over a year now sending faxes via Outlook and I would never go back to my old traditional fax machine.
                        Definitely worth taking a look at if you are looking for a reliable email fax provider. Plus they offer a 30 day free trial with no set up fees to ensure you can actually try the service for a month before you pay.
                        • 9. Re: Sending Fax via EMail
                          Faxtastic.co.uk
                          I've been using a free service over at www.faxtastic.co.uk which works great!
                          You can either pick a new fax number for free or use your existing number, once set up (in a matter of seconds) you can send and receive faxes to/from your email account, the faxes are sent as .PDF attachments to the email.
                          Check out www.faxtastic.co.uk and have a look, one of the best free email to fax/fax to email services I've found so far!
                          • 10. Re: Sending Fax via EMail
                            wryans Level 1
                            (Cameron_Howell) wrote:
                            Hello,
                            I agree with Cameron although I have been on hold for a little while the one time I needed support, but other than that they are a great service and friendly.
