5 Replies Latest reply on Dec 11, 2005 1:59 PM by (mnarewec)
    Emailing PDF - Encoding (MIME format) Problem
      Hi all,
      We are using Adobe Output Server Version 5.5.0.308 on a win2000 SP4 Server. We configured out Mailing Agent to use SMTP and the POP3-SMTPServer is a Domino Win2000 SP4 Lotus Notes.
      It has been working perfectly when the Lotus Notes Server is on Version 5.08. That is we were able to attached and email the PDF generated from Output Server using output Server.
      Recently, we upgrade the Lotus Notes Server to 5.013 and Out its emailing ok but the Content is in "Funny Messages"... Part of the Message is below. Is there anyway to solve this problem without 'downgrading' the Lotus Notes Server??
      I would really appreciate your help.
      "" This is part of the Attachment ""
      Date: 06 NOV 05 21:46:32 UT
      To: kayblow@xyz.com
      MIME-Version: 1.0
      Content-Type: multipart/mixed;
      boundary="----=_NextPart_000_1131313592"
      This is a multi-part message in MIME format.
      ------=_NextPart_000_1131313592
      Content-Type: text/plain;
      charset="ISO-8859-1"
      Content-Transfer-Encoding: 7bit
      For Your Information:
      1. This is an automated process sending out your statement. DO NOT REPLY to this email address. If you have any queries than please contact Engineering & Marine Services
      2. To read this statement you will require Adobe Acrobat Reader 5.0 or greater. You can download it from www.adobe.com/products/acrobat/readstep2.html
      Content-Type: application/octet-stream;
      name="Engineering & Marine Services Statement Number 00674202 Date 31-10-05 for Customer Delta Seafoods Pty Ltd.pdf"
      Content-Transfer-Encoding: base64
      Content-Disposition: attachment;
      filename="Engineering & Marine Services Statement Number 00674202 Date 31-10-05 for Customer Delta Seafoods Pty Ltd.pdf"
      JVBERi0xLjMNCiVKZXRGb3JtIFBERiBTdXBwb3J0IFZlcnNpb24gMi4zLjAwMA0KJUVuY29kaW5n
      T2JqZWN0PTANCiX7/P3+CjEgMCBvYmoKPDwKL1R5cGUgL0NhdGFsb2cKL1BhZ2VzIDMgMCBSCj4+
      CmVuZG9iagoNCjQgMCBvYmoKPDwKL1R5cGUgL0ZvbnQgL1N1YnR5cGUgL1R5cGUxIC9CYXNlRm9u
        • 1. Re: Emailing PDF - Encoding (MIME format) Problem
          Level 1
          I further investigated it to be "something to do with MIME Encoding"
          There is this MIME option in the JFEMAIL.INI where we set to NO and it was send OK buy now Our Lotus Notes Server trucates the PDF extension so users are unable to open the file.
          • 2. Re: Emailing PDF - Encoding (MIME format) Problem
            Level 1
            I wonder if your upgrade of Lotus Notes implemented a safety feature for "blocking" viruses & worms. At one time, for a short while, there was a version of PDF files that could be manipulated by the virus/worm designers - at least that is what I vaguely recall; for all I know it was just a rumor. Anyway, one way of getting by that would be to strip the extension so that a person could not blindly click on the attachment and have it open and do its dirty work. They would have to save the flie with the correct extension and then use Acrobat/Reader to open the file.
            If this is the case, then there might be an option within the server software for not messing with certain extensions.
            It might be helpful for you to know if the extension is being dropped by the server or by the user's client. If that is known you would have a better idea of where to look for an option to have it stop doing it.
            In the Microsoft Exchange/Outlook world it will totally drop the attached file if it has certain extensions. There is a client add-on product that allows a person to specify which extensions are to be allowed.
            • 3. Re: Emailing PDF - Encoding (MIME format) Problem
              Level 1
              Yeah Tom you're right. The extension is being droped off by the User's client. Its a mail reader preference set by the user to a user. When the user preference is set to Notes Rich Text Format, the extensions are being dropped off.
              Yep, the easier way is to detach file and rename the extension.
              • 4. Re: Emailing PDF - Encoding (MIME format) Problem
                Level 1
                But 'dull' users will still complain.. I was thinking if higher version of Adobe Output Server will solve this problem. I mean it should encode it in Mime Format correctly so that the Lotus Notes or whatever Mail Servers should decode it properly. I am more sure that It is the MIME thing encoding/decoding that is causing the problem.
                • 5. Re: Emailing PDF - Encoding (MIME format) Problem
                  Level 1
                  Here is part of the README.TXT file that Adobe sent together with the patch to correct this problem.
                  Patch Update to Messaging Agent 5.5
                  There is a known issue with Messaging Agent sending messages by SMTP (not MAPI) in these environments:
                  Windows Exchange 2000 Server
                  Windows Exchange 2003 Server
                  Domino Server 5.0.13a
                  The symptoms of the problem include the e-mail to, from, and date sent information found in the body of the message
                  but blank on the envelope of the message, empty attachments, or attachments in the body of the message displayed as base-64 encoded data.
                  The problem occurs because of a conflict between the line termination characters required by SMTP and the Exchange and Domino Servers. The SMTP standard stipulates that messages sent by it use CR/LF line termination characters. The Exchange and Domino Servers require that messages use LF line termination characters only, which is non-standard.
                  We recommend that you install the patch ONLY if you meet the following criteria. Only install the patch if you are using the SMTP protocol to communicate with an Exchange or Domino Server from Messaging Agent OR if you encounter these symptoms with another SMTP-based mail server.
                  With the patch, Messaging Agent recognizes two new settings that control the selection of the line termination characters. Specify the value of yes for one of these settings in order to resolve the issue described above:
