1 Reply Latest reply on Mar 7, 2006 12:56 AM by _MDI_
    Defining variables
    _MDI_ Level 1
      I am trying to map some field through the use of an external script file. I want to use different files basing the choice on a variable's value.
      So I pass the option "-advVAR=VALUE" by the "^JOB" line I have in the spool.
      The problem is that the script cannot find the variable as defined.
      It seems the -adv option doesn't work. If I use the -adp, it works, even if, to make it work, I have to use it in both the start-of-file script and in the section:* script...
        • 1. Re: Defining variables
          _MDI_ Level 1
          I've also seen that pre-defined variables don't work.
          I've a field named "Cognome" wich is mapped like this:
          b ^field Cognome
          b @Cognome
          I've changed it in:
          b ^field Cognome
          b @$date3.@Cognome
          but nothing is printed for @$date3.
          Anybody knows how to handle variables in scripts?...
          I would like to be able to recognize a variable passed with -adv option in the JOB command line.
          Thanx.
