4 Replies Latest reply on Jan 8, 2009 2:33 PM by BigJohnD
    Error 8013:0099 when doing a Save As
      Hello PageMaker community, I have a client that is using PageMaker 7.0.1a for on Windows XP Pro SP2 and every time they try to modify a file and choose "Save As..." they gets a message stating "The disk is full" and near the OK button it says (code: 8013:0099). They have plenty of drive space, no quotas turned on and full permissions to the directory. Scan disk turns up no errors as well. Any suggestions?
        • 1. Re: Error 8013:0099 when doing a Save As
          BigJohnD Level 3
          The usual responses are:
          1. Make sure the PM files and ALL linked files are on a local drive - no network links.
          2. Use only *.TIF and *.EPS formats for images and avoid windows metafiles (e.g. *.WMF, *.EMF)
          3. Do not embed ANY files (e.g. paste special)
          4. Check all fonts used for any corruption.
          5. Rename (i.e. temporarily delete) all the PM preferences file. (*.CNF in the folder "Program Files/Adobe/PageMaker 7.0/RSRC/[language] )
          6. Use a postscript printer driver as the "Compose to printer" and use the same driver in the print menu.
          7. Change the vid card screen settings to a basuc 800×600 and 256 colours.
          Further details in the FAQs.
          John Davies, "Table Of Contents - Complete Listing of All PM FAQ Topics" #1, 24 Dec 2003 5:03 am
          I see you have posted this question on several sites.
          Blwyddyn Newydd Dda! John
          14:10 01/01/2009 GMT
          • 2. Re: Error 8013:0099 when doing a Save As
            Level 1
            Thanks for the reply, here's what I got back from my client:
            I have not tried the suggestions, as not all are practical for this situation. For instance, this document requires the use of graphics that are stored on the network. I don't use windows metafiles and don't "paste special". I don't really know what you mean by "check fonts for any corruption." I compose to a postscript printer driver.
            Does anyone have anything more specific? Unfortunately, the client doesn't have a support contract with Adobe so I'm not able to go to their support for help at this time.
            Thanks in advance,
            Eric
            • 3. Re: Error 8013:0099 when doing a Save As
              BobLevine MVP & Adobe Community Professional
              If they're saving to a network drive they should try saving locally.
              There was a bug in Windows a while back where if you tried to save a
              file to a drive with a TB of free space Photoshop 7 would give the same
              error.
              I don't know if Pagemaker is affected by it but it's worth looking into.
              Speaking of looking into, I'd be remiss if I didn't mention the fact
              that PM is a dead application and that your client should be looking at
              InDesign.
              Bob
              • 4. Re: Error 8013:0099 when doing a Save As
                BigJohnD Level 3
                Best practice with PM requires all files to be local. Networks are far more reliable than they used to be, but PM pre-dates networks.
                Check out this FAQ:
                * Donald Gruener, "7.2 - Network Issues" #1, 19 Jan 2002 10:13 am
                Remove and re-install from the original source any fonts used in the Publication.
                The ideal solution is move onto to InDesign.
                Iechyd da! John
                22:33 08/01/2009 GMT
