7 Replies Latest reply on Nov 13, 2008 8:44 AM by Ned Murphy
    set the alpha of all MCs with specific name
    elic05
      i want to loop throught all my movieclips and all the movieclips that have the name "bgTitle" i wand to set there alpha to 50%
      (in my case the movieclips i am looking for are instances of the same mc that i have in the library.)
        • 1. Re: set the alpha of all MCs with specific name
          Okay, what problem are you having? In case... if you gave them all the same instance name, you can't change them all.
          • 2. set the alpha of all MCs with specific name
            elic05 Level 1
            they are instances of a mc but they are not on the same time line.
            i have a mc named msgbox and inside it a mc named bgTitle, and i have also a mc that is named basket and inside it a mc named bgTitle,
            there are 2 mcs that are instances of the same mc but have diffrent path
            (actually i have much more than 2)
            • 3. set the alpha of all MCs with specific name
              Well, if you want to loop thru all the movies, then you need to have their instances names stored in an array so that you can loop thru that array in targeting them.
              var mc_Names = new Array("msgbox","basket",....);
              for(z=0; z<mc_Names.length; z++){
              this[mc_Names[z]].bgTitle._alpha = 50;
              • 4. Re: set the alpha of all MCs with specific name
                elic05 Level 1
                its good for my example but the bgTitle is sometimes nested deep inside a mc and it can be also on the main timeline (_root)
                i found this few lines of code that suppose to do the job, but they dont
                function findClips (myClip, indentSpaces) {
                // Use spaces to indent the child clips on each successive tier
                var indent = " ";
                for (var i = 0; i < indentSpaces; i++) {
                indent += " ";
                for (var property in myClip) {
                // Check if the current property of myClip is a movie clip
                if (typeof myClip[property] == "movieclip") {
                trace(indent + myClip[property]._name);
                // Check if this clip is parent to any other clips
                findClips(myClip[property], indentSpaces + 4);
                findClips (_root, 0); // Find all clip instances descended from main timeline
                i took if from
                http://oreilly.com/catalog/actscript/chapter/ch13.html
                exaple 13-3
                • 5. set the alpha of all MCs with specific name
                  Your first sentence of your last reply made things much clearer.
                  That code you took from OReilly works fine for what it says it does, but you need to add some code to it to make it target the movieclips and change the alpha. Since I've never done it before, I spent some time figuring out how to make that happen (partly for you, but mostly for me). I've removed all of the tracing related code so that it doesn't get in the way of helping you to understand what is going on.
                  • 6. set the alpha of all MCs with specific name
                    elic05 Level 1
                    thanks a lot Ned
                    for me it didnt work
                    the original version
                    I work with cs3,as2
                    i found out why
                    cause i have 2 mc that belongs to flash
                    and it caused the function to be endless
                    i added an if and it is working fine
                    if (property != "reserved" && property != "focusManager") {
                    you version that is lookink for a specific name
                    doent fine that two mc that cause the problem
                    • 7. set the alpha of all MCs with specific name
                      I'm using CS3 as well. Yes, that function is not intended to find coding issues, just the mc that you said you wanted to find. Coding issues always lead to bad behavior.
