1 Reply Latest reply on Jan 18, 2012 5:26 AM by Manish Jayprakash Sankhe
    Compiling Library project with compc ant tasks
    Jack_Brinks
      Guys, Please help in finding the problem with this.
      Flex builder builds the project without any errors. I checked for all setting in flex builder project and replicated the same in my ant task. But my ant task throws this error.
      Error: Unable to locate specified base class 'mx.controls.DataGrid' for component class 'com.bgs.components.extended.DataGridBase'.
      DataGridBase is my custom component extending DataGrid.
      DataGridBase.mxml has
      <mx:DataGrid
      xmlns:mx=" http://www.adobe.com/2006/mxml"
      xmlns:local="*"
      creationComplete="initializeDataGrid();"
      itemEditBegin="setEditorRestrictions(event);"
      // my custom script
      </mx:DataGrid>
      my ant task is
      <target name="FlexComponentLibrary">
      <echo>ActionScript classes: [${flex.classes}]</echo>
      <delete file="${OUTPUT_FOLDER}/FlexComponentLibrary.swc"/>
      <compc include-classes="${flex.classes}"
      output="${OUTPUT_FOLDER}/FlexComponentLibrary.swc"
      strict="true"
      warnings="true"
      accessible="true"
      include-lookup-only="false"
      <load-config filename="${FLEX_HOME}/frameworks/dumpLib.xml"/>
      <source-path path-element="${SOURCE_FOLDER}" />
      <library-path dir="${FLEX_HOME}/frameworks/libs"
      includes="automation.swc,automation_agent.swc,automation_dmv.swc,automation_flashflexkit. swc,datavisualization.swc,flex.swc,framework.swc,qtp.swc,rpc.swc,utilities.swc" append="true"/>
      <library-path dir="${FLEX_HOME}/frameworks/locale/{locale}" append="true"/>
      <library-path dir="libs" includes="granite.swc,granite-hibernate.swc,gravity.swc" append="true"/>
      <external-library-path dir="${FLEX_HOME}/frameworks/libs/player" includes="playerglobal.swc"/>
      <library-path dir="../FlexLibrary/bin" includes="FlexLibrary.swc" append="true"/>
      </compc>
      </target>
      I am unable to find out if flex builder while building internally adds or does something to take out this error.
