9 Replies Latest reply on Nov 7, 2008 6:30 AM by heathrowe
    HOWTO: Pixelization in Fireworks?
    dumbled@d
      Hi All,
      I'm trying to do pixelization ( http://en.wikipedia.org/wiki/Pixelization ) in Fireworks. Here's the workflow I was hoping would work:
      1) Select the area of the image to be pixelized and copy it as a new image;
      2) Resize the new image to a very few number of pixels;
      3) Paste the new image back onto the original as a new layer;
      4) Resize the layer until it matches the original; and
      5) Line up the new layer so that it obscures the correct portion of the original. Job done.
      Only it doesn't work quite as I expected. In step (4), instead of each square growing in size as the layer is resized, Fireworks interpolates and adds new squares so that the pixelated portion appears to get more accurate, more detailed. How can I resize the layer without Fireworks doing anything but resize?
      Here's an example that's almost (but not quite, see the PS) what I mean: http://www.flickr.com/photos/dumbledad/3004381461/
      Cheers,
      Tim.
      PS I know that Photoshop has a filter that does almost exactly what I want – a mosaic pixelization. But I'm having other problems with that (I don't know how to prevent alpha-blended transparency on the outlying pixels) that I'll probably ask elsewhere.
        • 1. Re: HOWTO: Pixelization in Fireworks?
          Level 7
          On Wed, 05 Nov 2008 13:59:18 +0300, Dumble_dad
          <webforumsuser@macromedia.com> wrote:
          > Hi All,
          > image;
          > original. Job done.
          > square
          > new
          > resize?
          Should be easy. In your newly pasted image, use "Image size" and reduce
          it, choosing "Nearest neighbour" as interpolation algorithm. Them
          immediately increase image size back, using "Nearest neighbour" again.
          Ilya Razmanov
          http://photoshop.msk.ru - Photoshop plug-in filters
          • 2. Re: HOWTO: Pixelization in Fireworks?
            heathrowe Most Valuable Participant
            Nice trick Ilya
            I just tried this and it worked well, though not without trial and error.
            You have to Resize 'down' to an incredibly smaller ratio of the original before Resizing it back up again.
            h
            • 3. Re: HOWTO: Pixelization in Fireworks?
              Level 7
              On Thu, 06 Nov 2008 18:07:07 +0300, heathrowe
              > Nice trick Ilya
              > error.
              Yes, that's what I ment by saying "use "Image size" and reduce it", sorry
              if it wasn't clear. The main idea is that you "kill" pixels first, then
              "restore" them using "Nearest neighbour", which is interpolation "by
              constant" and so, unlike interpolation "by line" or "by cubic curve", it
              is guaranteed to produce big flat areas you need for you purpose instead
              of smooth transitions.
              Ilya Razmanov
              • 4. Re: HOWTO: Pixelization in Fireworks?
                Indeed thanks - now to remember to reset the interopolation back to the default after using this is another 'trick'. Cheers
                h
                • 5. HOWTO: Pixelization in Fireworks?
                  SiamJai Level 2
                  quote:
                  Originally posted by: Dumble_dad
                  Hi All,
                  Cheers,
                  Tim.
                  Hi Tim,
                  You could try selective JPEG compression to get rid of alpha blending around the edges and add large pixellated areas. Here is a short tutorial on the technique. Combine it with the workflow you used before, and hopefully it will give your pics the right look.
                  Best luck!
                  SiamJai
                  http://design.thaiwonders.com - Innovative Fireworks Tutorials
                  • 6. Re: HOWTO: Pixelization in Fireworks?
                    Level 7
                    Hi, There is a tutorial by Kim Cananaugh on the CMX site explaining exactly
                    how to do this....
                    http://www.communitymx.com/content/article.cfm?cid=AE3342BFEA8059EF
                    Peter
                    _______________
                    "Dumble_dad" <webforumsuser@macromedia.com> wrote in message
                    news:gerua6$elk$1@forums.macromedia.com...
                    | Hi All,
                    in
                    image;
                    | original. Job done.
                    square
                    new
                    | resize?
                    | Cheers,
                    | Tim.
                    ? a
                    how
                    • 7. Re: HOWTO: Pixelization in Fireworks?
                      SiamJai Level 2
                      Peter,
                      Thanks for the link, but that tutorial seems to be reserved exclusively for CMX members. Non-members see only the login screen. :(
                      • 8. Re: HOWTO: Pixelization in Fireworks?
                        ageofem Level 1
                        hi tim , try this pixelate plugin by richard rosenman , just try to locate the ps plugin folder in your preferrences, there are also other cool free plugins that can be used in fw too.
                        http://www.richardrosenman.com/media/software/files/pixelate.zip
                        his other plugins
                        http://www.richardrosenman.com/software/downloads/
                        my thoughts on this would be, make your image a bitmap first , then make a selection using the polygon tool to areas you want to pixelate, then apply the filter, hope that works =)
                        • 9. Re: HOWTO: Pixelization in Fireworks?
                          his other plugins
                          I was just about to suggest the same thing :)
                          Too bad it's not possible (not that I am aware of) to have it as a Live Filter.
                          h
