9 Replies Latest reply on Mar 8, 2012 4:01 AM by abhisekpaul02
    Converting XMLList to ArrayCollection
      Hi, I have an XML List as follows :
      <items name="total">
      <item name="value1" percentage="35"/>
      <item name="value2" percentage="25"/>
      <item name="value3" percentage="47"/>
      <item name="value4" percentage="89"/>
      </items>
      <items name="somesub">
      <item name="value1" percentage="15"/>
      <item name="value2" percentage="27"/>
      <item name="value3" percentage="56"/>
      <item name="value4" percentage="43"/>
      </items>
      and I need to dynamically convert it to an array collection as follows (I'm loading the XML externally and the component only allows for an arrayCollection) :
      myArray = new ArrayCollection(
      { name:"total", value1:35, value2:25, value3:47, value4:89},
      { name:"somesub", value1:15, value2:27, value3:56, value4:43}
      I'm totally stuck on how to do this so any help putting me in the right direction would be highly appreciated.
        • 1. Re: Converting XMLList to ArrayCollection
          atta707 Level 2
          Two things come to mind:
          You can set the result type to object and let HTTPService to the heavy lifting of converting XML to Objects for you:
          http://blog.flexexamples.com/2007/09/19/converting-xml-to-objects-using-the-flex-httpservi ce-mxml-tag/
          or you receive data as XML and use SimpleXMLDecoder class to convert it into objects and add them to a ArrayCollection
          ATTA
          • 2. Converting XMLList to ArrayCollection
            Level 1
            Not too sure that this is the solution I need, I'm not familiar with the SimpleXMLDecoder function but it looks as if the XML data itself needs to be modelled already in order to be succesful.
            I'm already a bit further on my quest to a solution, converting the content to an object does the trick indeed, at least when I hardcode it. I still am stuck on how to do this programatically / dynamic.
            eg : the XMLdata is
            </items
            and this needs to be dynamically converted to an object as follows :
            var obj:Object = {name:"total", value1:35, value2:25, value3:47, value4:89}
            Once I have this object the rest is simple, but I fail to do this conversion properly...
            • 3. Re: Converting XMLList to ArrayCollection
              sagisid
              its been a year since there was any activity on this thread so, is the question answered ?
              if not... you can you an intermediate array and push elements one by one inside it and the convert this array into arraycollection.
              • 4. Re: Converting XMLList to ArrayCollection
                AICC Level 1
                This works partiallly but it keeps all the XML Node names??  AND WHEN USED WITH A DATAGRID SEARCH iT BLOW UP IN FLEX
                so help would still be nice
                myData = new ArrayCollection(mx.utils.ArrayUtil.toArray(xmlStudents));
                I found it on:
                http://www.flexdeveloper.eu/forums/actionscript-3-0/converting-xml-to-arraycollection/
                I ultimately needed it for this code examples:
                HOW TO SEARCH A DATAGRID?
                http://www.flex-blog.com/arraycollection-filter-example/
                Thanks.
                Doug Lubey of Louisiana
                www.douglubey.com
                SEARCH ENGINE REFERENCE:
                flex4 datagrid search filter 2010
                flex4 datagrid search filter columns
                flex4 datagrid example with search filters
                adobe flex4 convert fx:XMLList to arraylist
                flex4 convert XMLList to arraylist
                flashbuilder4 convert xml to arraylist
                flex xml to arraylist
                convert xmllist to arraycollection in flex
                Implicit coercion of a value of type XMLList to an unrelated type mx.collections:ArrayList
                • 5. Re: Converting XMLList to ArrayCollection
                  BhaskerChari Level 4
                  Here is the code which converts XMLList to an arraycollection...
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="init();" layout="absolute">
                  <mx:Script>
                    <![CDATA[
                     import mx.collections.ArrayCollection;
                     import mx.rpc.xml.SimpleXMLDecoder;
                     private var acAllNodes:ArrayCollection;
                     private var acOpenNodes:ArrayCollection;
                     private function init():void
                      convertXmlListToArrayCollection();
                     private function convertXmlListToArrayCollection():void
                      var strXML:String = dpNodes.toXMLString();
                      strXML = "<root>" + strXML + "</root>";
                      var xml:XML = new XML(strXML);
                      var xmlDoc:XMLDocument = new XMLDocument(xml);
                      var decoder:SimpleXMLDecoder = new SimpleXMLDecoder(true);
                      var resultObj:Object = decoder.decodeXML(xmlDoc);
                      acAllNodes = new ArrayCollection();
                      if(resultObj.root.hasOwnProperty("items"))
                       if(resultObj.root.items is ArrayCollection)
                        acAllNodes = resultObj.root.items;
                       else if(resultObj.root.items is Object)
                        acAllNodes.addItem(resultObj.root.items);
                  </mx:Script>
                  <mx:XMLListCollection id="dpNodes">
                          <mx:source>
                              <mx:XMLList>
                      </items>
                      </items>
                              </mx:XMLList>
                          </mx:source>
                      </mx:XMLListCollection>
                  </mx:Application>
                  If this post answers your question or helps, please kindly mark it as such.
                  Bhasker Chari
                  • 6. Re: Converting XMLList to ArrayCollection
                    AICC Level 1
                    Bhasker,
                    YES your solution worked...thanks.
                         It does appear to be customized for each Xml document which uses different node names.  Took me 5 minutes to figure out your XML Set started with "items" where as mine started with "student"...thanks.
                    other than it worked perfectly:
                    var strXML:String = xmlStudents.toXMLString();
                    strXML =
                    //Alert.show(strXML, 'Alert Box', mx.controls.Alert.OK);
                    myData =
                    if(resultObj.root.hasOwnProperty("student"))
                    if(resultObj.root.student is ArrayCollection)
                    myData = resultObj.root.student;
                    else if(resultObj.root.student is Object)
                    myData.addItem(resultObj.root.student);
                    HERE IS MY fx:XMLLIST I based
                    <fx:XMLList id="xmlStudents">
                         <student>
                         <id>1</id>
                         <name>Christina Coenraets</name>
                         <phone>555-219-2270</phone>
                         <email>ccoenraets@fictitious.com</email>
                         <active>true</active>
                         <image>images/arrow_icon_sm1.png</image>
                         </student>
                    </fx:XMLList>
                    • 7. Re: Converting XMLList to ArrayCollection
                      Hi AICC,
                      I am glad it worked for you....Have a happy coding..
                      Bhasker
                      • 8. Re: Converting XMLList to ArrayCollection
                        vipx
                        How i can do. if i want also childern from xml list.
                        if i am doing same way you show here and bind with tree its only give me the parent node its not give to me the childerns.
                        i stuck with my tree please let me know the solution.
                        thanks in advanced
