1 Reply Latest reply on Nov 19, 2008 5:45 PM by injpix
    Customize ProgressBar
    Emiliano85
      Hi , i'm new to flex 3 , and i need to make the progressbar to look like in the image from the link.
      there should be 4 colors , from red(25%), orange(50%),yellow(75%) to green(100%)
      there should be an gradient from up to down of each color, darker to lighter
      http://img520.imageshack.us/my.php?image=progressbaroh7.jpg
      thx
        • 1. Re: Customize ProgressBar
          injpix Level 3
          I don’t see an easy way of doing it. There are some things you can *try* to do, such as:
          -Create a subclass of ProgressBarSkin and override drawRoundRect method. And in your MXML code you would set the barSkin to this subclass.
          -Create a subclass of ProgressSkin and override createBar and/or createTrack. Then instead of using the mx namespace for the ProgressBar in your MXML code, you would use a custom namespace.
          I have tried neither methods; so I may be leading you down a dead end.
