10 Replies Latest reply: Nov 14, 2008 12:59 PM by Newsgroup_User RSS
    Formatting Links in Libarary Item
    andrewmcgibbon Community Member
      How do you format links (hover, active, etc.) that appear in a library item? I have put inline styles into the body of the libarary page, but I found that it was overwriting the link styles of the style sheet attached to the page where the libarary item is inserted.
      Would anyone be so kind as to explain the best way to control this?
      Many thanks,
      Andy
        • 1. Re: Formatting Links in Libarary Item
          Newsgroup_User Community Member
          The markup to format the links would have to be already in the parent page
          (the one into which the Library item is inserted). Get it?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "andrewmcgibbon" <webforumsuser@macromedia.com> wrote in message
          news:gfkhmr$h3f$1@forums.macromedia.com...
          > item? I
          > that it
          > where
          > Many thanks,
          > Andy
          • 2. Re: Formatting Links in Libarary Item
            Use a CSS style (either a stylesheet attached to the page or in the head,
            not inline) to control it.
            > Many thanks,
            > Andy
            • 3. Re: Formatting Links in Libarary Item
              You wouldn't attach a stylesheet to a Library item. NONONONONO.
              And it doesn't have a <head> (or it shouldn't).
              "Mad Dog" <md@maddogproductions-remove.com> wrote in message
              news:gfkijo$i51$1@forums.macromedia.com...
              >> Many thanks,
              >> Andy
              • 4. Re: Formatting Links in Libarary Item
                But you can attach a design time style sheet to the Library item (.lbi file): Format -> CSS Styles -> Design Time
                I think that part of the issue with the OP is that they would also need to "scope" the code in the Library item (perhaps by adding an ID to a wrapper div) so that styles that are to be applied to the library item contents do not overwrite the styles when viewed within the pages that the library item resides.
                Danilo Celic
                | http://blog.extensioneering.com/
                | WebAssist Extensioneer
                • 5. Re: Formatting Links in Libarary Item
                  Danilo, could you expand on what you said about the adding a div tag to the text in the library item? I am assuming that this is where you would reference the style to be used?
                  Thank you all so much for your help.
                  Andy
                  • 6. Re: Formatting Links in Libarary Item
                    If the styles in the main pages are in an external linked .css file, then
                    attach a "design time" stylesheet to the library item.
                    Then the styles from the external css file will show and be usable/editable
                    when you have the .lbi file open.
                    Alan
                    Adobe Community Expert, dreamweaver
                    http://www.adobe.com/communities/experts/
                    • 7. Re: Formatting Links in Libarary Item
                      Huh? The rules that would cascade into the Library item must already be
                      present in the parent page. You would not need to scope anything.
                      "danilocelic AdobeCommunityExpert" <danilo@shimmerphase.com> wrote in
                      message news:gfkjjv$jfr$1@forums.macromedia.com...
                      > item resides.
                      > Danilo Celic
                      • 8. Re: Formatting Links in Libarary Item
                        Sorry if I wasn't clear. Of course you wouldn't (and can't). You'd attach if
                        to the document(s) that call(s) the Library Item.
                        sheesh!
                        >> head, not inline) to control it.
                        >>> inserted. Would anyone be so kind as to explain the best way to control
                        >>> this?
                        >>> Many thanks,
                        >>> Andy
                        • 9. Re: Formatting Links in Libarary Item
                          One of the problems mentioned in the OP was that the styles they were using for the library item were overwriting the link styles for the completed page. I took that to mean that the links in the library item are supposed to be styled differently than the rest of the page. If that is the case (could use some clarification from the OP), then adding a wrapper div (or iding an existing container) and then specify the links styles similar to the following would achieve that goal:
                          #myLibraryItem a:link{
                          text-decoration:none;
                          #myLibraryItem a:hover{
                          text-decoration:underline
                          Does that make more sense?
                          Danilo Celic
                          • 10. Re: Formatting Links in Libarary Item
                            Yes.
                            message news:gfkns8$ope$1@forums.macromedia.com...
                            > Danilo Celic
