9 Replies Latest reply on Nov 25, 2008 12:31 AM by Peter Grainge
    Favicon for context-sensitive Help (WebHelp)
    LuckyClover Level 1
      Hi. I've created a WebHelp project for a Web-based software application, and it includes context-sensitive topics. When these topics are launched from the application, the icon of the browser is displayed in the topic frame. Is there a way to replace this with a custom icon (favicon)? We want to match the favicon that is used with the product, to the Help output. There is a ton of information about creating favicons online, but not much when it comes to tweaking HTML source for WebHelp projects. Any tips/ideas are welcome!
        • 1. Re: Favicon for context-sensitive Help (WebHelp)
          <quote>When these topics are launched from the application, the icon of the browser is displayed in the topic frame.</quote>
          Browser icon in the topic frame? The topic only has what you put in it. Can you explain more?
          • 2. Re: Favicon for context-sensitive Help (WebHelp)
            LuckyClover Level 1
            Hi, Peter. When the context-sensitive topic is invoked from the (Web-based) application, the user's browser information is displayed in the top portion of the window (the default browser frame). In this case, the user will see a URL and the browser icon (IE). I'm wondering whether it is possible to overwrite any browser favicon (such as the IE logo) with the product favicon (for example, adding a line of code to each topic)? Our developers are very concerned about the consistency of how information is presented, and I agree, it would be nice not to have to see different icons throughout the Help (such as the whstart.ico when the main product help is launched, which I have replaced with our favicon).
            • 3. Re: Favicon for context-sensitive Help (WebHelp)
              Hi LuckyClover
              What you may wish to try is to insert a line in your HTML code that looks like this:
              <LINK REL="SHORTCUT ICON" HREF="InsertURLHere/favicon.ico" />
              Note that I said "try". I said this because sometimes RoboHelp tries to be ever helpful and amends (read - removes) things we add in TrueCode view.
              Of course, you would want to save your personalized icon as "favicon.ico".
              Cheers... Rick
              • 4. Re: Favicon for context-sensitive Help (WebHelp)
                Now I understand, you are referring to how to get an icon such as I have on my site. It was the reference to the topic frame that through me. You are referring to the address bar.
                I see Rick has explained how.
                • 5. Re: Favicon for context-sensitive Help (WebHelp)
                  LuckyClover Level 1
                  Hi, Rick. Why is it important to name the favicon, "favicon", specifically? Also, I'm not sure what I would use for the portion of the inserted code, ="InsertURLHere
                  So, I'll give this a try in some of context-sensitive topics. Is there a way that I can test this on my computer? Right now, I'm checking the output from the WebHelp folder (launching the Help start page, index.htm). I understand that I can probably see changes by publishing (HTML), but I don't have a server for this (publishing as a local file system). Thanks again.
                  • 6. Re: Favicon for context-sensitive Help (WebHelp)
                    Hi there
                    Assuming your site has a known URL (such as http://www.RoboWizard.com or something similar) that is what you would be expected to place there.
                    You may wish to review the link below:
                    Click here for more
                    Cheers... Rick
                    • 7. Favicon for context-sensitive Help (WebHelp)
                      LuckyClover Level 1
                      Well, I changed the header code for the Help project start page (index.htm) as follows:
                      var sIcon="favicon.ico";
                      Also, as a test, I added the following code to the header portion of some of the context-sensitive topics
                      <link rel="shortcut icon" href="favicon.ico">
                      And voila, nothing works. Our developer took the code and made a sample html page, and when we opened the page in Mozilla, the favicon displays. The same page doesn't display in IE (we need our favicon to work in IE 6.0). I have the favicon in the WebHelp output folder, also. Can anyone tell whether the HTML changes are off/wrong or whether there is an issue with IE 6.0 with rendering the requested changes?
                      Thank you.
                      • 8. Re: Favicon for context-sensitive Help (WebHelp)
                        RoboWizard Level 4
                        Hi again LuckyClover
                        Where the icon isn't appearing, is the topic by chance inside a folder? If so, that probably explains why it's failing. Your code is specifying only the icon and no path. So if the topic is inside a folder, it can't find the icon.
                        Cheers... Rick
                        • 9. Re: Favicon for context-sensitive Help (WebHelp)
                          Do some googling on this. I did to get the favicon working on my site. One of the pages I found indicated that FF responds immediately but IE can take a while.
