2 Replies Latest reply on Aug 30, 2008 8:06 AM by Zacb
    Custom tooltip won't work in Datagrid
    Zacb
      I have a datagrid that we have created a custom tooltip for. We can't use a Datatip or standard tooltip due to the client's requirements. The datagrid column has a custom itemrenderer that also creates the tooltip
      It works fine except in cases where the text in the column is not truncated. If the text is truncated then the tooltip pops up. If it isn't then it won't appear at all
      This also was the case with the default tooltip for the datagrid prior to adding the itemrenderer
      Does anyone know how to get the tooltip to trigger even when the text is not truncated?
      TIA
